Results 1 to 10 of 10
    Phoenix,AZ
    Tstat wire and network
    Will 24v TSAT wire cause glitches in a network cable if ran in same conduit? Boss said it would. Network guy said he didn't think so. Who's right?
    Jul 2019
    Oklahoma home its in the name
    Quote Originally Posted by KB Cool View Post
    It only seems reasonable that it could. But there are many types of network cables. Is it shielded or not?
    I would think better safe than sorry.
    Sent from my "smart" phone using Tapatalk
  3. Likes Metalman0880 liked this post.
  4. #3
    Phoenix,AZ
    Quote Originally Posted by R600a View Post
    I'm not sure if it was shielded. Looked like regular ethernet cable that hangs off the back of my router that sits on top of my PC tower and that cable then crosses paths with my 120v a/c power cord. You see what i'm getting at? If I remember right I think there were some minisplits that didn't want the HV mixed w/ the com cables. Not 100% sure though. Been a long time.
  5. #4
    Jul 2019
    There is a big difference between crossing and running alongside for a distance.
    Two wires running alongside each other can induce currents in each other.
  6. #5
    Phoenix,AZ
    What like how a PSR relay takes out the start cap?
  7. #6
    Jul 2019
    No. More like how the secondary winding of a transformer has power eaven though it is not connected to the primary winding.
  8. #7
    Nov 2011
    East Side
    I don't know that low voltage and low amperage thermostat wire would cause interference, but it's always recommended to separate data cable from any electrical wiring.
    best practice is to not run those cables in the same conduit.
    Personally, I don't think it would cause any problems, but what if it does? Then you have to redo a job that should have been done differently in the beginning. could mean the difference between making money and losing money.....better safe than sorry.
  9. #8
    Southold, NY
    Standard T-Stat (Open Closed circuits) wire being in close contact with line voltage is not an issue.
    Communication cable pulled in the same conduit as line voltage is a no no!
  10. #9
    Did NEC change from ALL wiring in conduit MUST have same rated insulation? The intent of that is to prevent electrical interference/electric field generation.
  11. Likes N2fords liked this post.
  12. #10
    Southold, NY
    Quote Originally Posted by dandyme View Post
    As far as I’m aware it hasn’t changed.
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
