Results 1 to 13 of 14
    Mar 2020
    generator running ac unit
    Hi, I am new to this forum. I have a 15,000 continuous watt/ 22,000 surge watt backup generator. I have attached a picture (if I did that correctly) of the information label on the outside unit. I also have an air handler in my attic but do not have any specific information on it. I tested the generator and it will indeed run my unit, but seemed like the unit fan outside and the air handler inside were running slower than normal. My question is should this generator be able to run this unit (with no other load except a couple of led lights) and if the unit is indeed running slower can that cause damage to the unit. Any help would be appreciated. Thank you.
    Aug 2015
    Buffalo,NY
    Well 15,000 watts is 62.5 Amps. According to your data tag your condenser consumes 19.5 Amps. Now depend on air handler and whatever else is running off the switch you should be ok. But only diagnostic equipment is truly going to answer your question.
    What was the voltage and frequency at the AC unit while it was operating?
    PHM
    Quote Originally Posted by whitcarroll24 View Post
    PHM
  4. Likes dan sw fl liked this post.
  5. #4
    Oct 2014
    Saint Pail, Minnesota
    This sounds like a AOP topic.
  6. #5
    Dec 2006
    Vancouver, B.C.
    Check your frequency and report back.
    Quickly, I must hurry, for there go my people and I am their leader!
  7. #6
    Mar 2010
    Woodbridge, VA
    Newer HVAC motors (non-psc) do not like dirty power from generators. Will it work? Yes in most cases. Will you have problems? I've seen quite a bit.
  8. #7
    Moved to AOP.
  9. #8
    Southold, NY
    If you want A/C on a generator get a small window shaker and plug it in.
  10. #9
    How about mini splits? Would they work OK on generator power?
    PHM
    PHM
  11. #10
    Southold, NY
    PHM
    Minis with an invertor compressors are your best bet for having enough power available to get the compressor up to speed. Again the smallest possible is the key.
    The OP is showing a 3 1/2 -Ton A/C that draws several hundred amps on start up.
  12. #11
    SW FL
    Quote Originally Posted by ziggyhere View Post
    OP, Did you measure the Voltage AT THE CONDENSER?
    Running Amps is not an issue, IF the actual voltage is > 210 V.
    Start-up Amps could be a problem.
    However, the duration might be < 1 second.
    Designer Dan
  13. #12
    Mar 2009
    Mount Holly, NC
    That equipment came with either no startup aids, or a thermistor aid...
    I would recommend you have installed 521 compressor saver start assist kit.
    This will help your system operate properly on startup by drastically reducing the startup surge duration
    The TRUE highest cost system is the system not installed properly...
    Find a HVAC-Talk Contractor by clicking here
    Click below to BECOME a pro member
    https://hvac-talk.com/vbb/forumdispl...ip-Information
    Do you go to a boat repairman with a sinking boat, and tell him to put in a bigger motor when he tells you to fix the holes?
    I am yourmrfixit
  14. #13
    Me too!!!
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
