    Mar 2020
    2.5 single or 3t 2 stage?
    This question is very similar to a question below but.
    Im now looking to replace. Manual J has my 1400sf home (Dallas TX) at 2.38. I am replacing a 3t unit that has always been too large.
    The price differences between a 2.5 Single stage vs a 3T 2 Stage is fine with me if it will run longer and dehumidify.
    Is this a good candidate for the 3T, 2 stage? The ducting is on the edge of 1200cfm. A return would need to be added.
    I dont mind spending he money if this will help with humidity in the spring and deal with the 108F temps in the summer, but dont want to spend more and still have issues.
    Im guessing a 3t 2 stage should be designed for a 3ton home, but the 1 ton increments tend to screw that.
    Do the r410 systems do a better/worse job at removing humidity? Or approx the same?
    Southold, NY
    2-ton with a whole house dehumidifier!
    Athens, Ohio
    Does Dallas have humidity?
    I love our dehumidifier in our green grass area in Ohio.
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
    SW FL
    Quote Originally Posted by yesterday View Post
    I'm now looking to replace.
    The ducting is on the edge of 1200 cfm.
    and deal with the 108F temps in the summer, but don't want to spend more and still have issues.
    Two stage system Will run longer and dehumidify
    IF it is sized appropriately and air flow is set accurately.
    I would not take someone else's calculation at face value
    given 2.38 and Your situation / locale.
    Q. Sensible _ _, _ _ _ BTU/HR
    S.H.R. ___ 0. _ _
    DeRate at 110'F ________
    Age of house __ / Built 1999 or ___
    Windows: _S.H.G.C. 0._ _ [ < 0.29 ?]
    Glass Area: ___ Sq Feet
    Infiltration: 0._ _ A.C.H. Natural
    ASHRAE 1%
    99.1'F DB
    74.5'F WB ______ R.H. 31.9%
    2,878 Cooling Degree Days
    2,161 Heating Degree Days
    My Gmail address: racingdan11
    Designer Dan
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
