Return air drop to new filter rack
I currently have a 16x25x1 builder grade filter handler. I'm looking to install a lennox 5" filter. Currently there is a 90 degree soft radius (outside edge only) going into the filter. The return drop is 10x25 and it's a 3.5 ton system. I have contacted a few HVAC installers for the new filter rack. Most of them recommended just bringing the 10x25 all the way down, cap the end off, and put the air rack between that and the furnace. I'm no expert, but is that OK for air flow? I just figured they soft 90 radius was there for a reason. Though the more I looked it seems like unless it's a soft radius on interior AND exterior it doesn't do much. Will the plan work fine? Last thing I want to do is make my return noticeably less efficient. Thanks!
Also, how does the Lennox HC compare to the same size aprilaire system? Should I hold out for an aprilaire or they more or less the same difference? I have an aprilaire on my old house and liked it, never ventured into lennox.
Originally Posted by
needshvac
I just figured the soft 90 radius was there for a reason.
Last thing U want to do
Listen to someone who does not wish to present the
overall system operating perspective.
Filter location may be necessary to be in the vertical drop.
__ Fit-up issues to be addressed
FACTS to investigate
1
E.S.P. Analysis of current operation
_____-- Supply, Return, Filter & Total dP
2
Comprehensive ACCA Manual D calculation
3
Required system flow rate may be 360 to 450 CFM / Ton
depending on Location _________ Humid ___ Dry Region
4
Mfg. / Model number of air handler / furnace ___________
My Gmail address: racingdan11
Designer Dan __ It's Not Rocket Science, But
It is SCIENCE with
Some Art. _ _
KEEP
IT
SIMPLE &
SINCERE ___ __
www.mysimplifiedhvac.com ___ __ Define the Building Envelope & Perform a Detailed Load Calc: It's ALL About Windows & Make-up Air Requirements. Know Your Equipment Capabilities
Post Likes - 1 Likes, 0 Dislikes
