Results 1 to 11 of 11
    Sep 2014
    Portland, Oregon, United States
    Hall effect sensors
    Why/how is it I see a lot of these draft motors on rooftop units that have the wires cut to the hall effect sensor? Is this a way to bypass the sensor somehow? Units are still heating..
    Jul 2011
    DFW, TX.
    Quote Originally Posted by heatingelement View Post
    Carrier?
    Sent from my LG-G710 using Tapatalk
    May 2014
    Bay Area California
    Are any of those wires spliced together? I did not think the unit would heat without that sensor properly plugged into the board.
    I do a triple evac with nitro to remove non condensables.
  4. Likes CEAS-AC-TECH liked this post.
  5. #4
    Jan 2010
    Did you see a pressure switch ?
  6. #5
    Virginia
    What is the model number?
  7. #6
    Southold, NY
    Emergency stairs?
    Hotel, Motel Common hallways?
  8. #7
    Jan 2010
    Quote Originally Posted by rundawg View Post
    I suspect either pre or post hall effects sensors used by Carrier.
  9. Likes CEAS-AC-TECH liked this post.
  10. #8
    Sep 2014
    Yes, carriers. I didn't look into them or grab the models. Just came to me as an after thought. Next time I run into one, I'll look into it more.
  11. #9
    May 2014
    Bay Area California
    Maybe someone picked up a motor with the Hall Effect and went to replace a motor with the two wire centrifugal switch. Couldn't figure it out, so installed the motor, cut the three wires to the plug, and wire nutted the two wires that went to the original motor's centrifugal switch.
    That could be a reasonable scenario, for a hack.
    On a bit of tangent:
    The first time I heard about a Hall Effect Transistor, yes, that's what they called it when I first heard about it, was in something like a Popular Mechanics. Can't remember for sure. Might have even been Scientific American. Any way, the article was extremely interesting to me.
    They were describing how the heart beat of a fly was measured with one.
    I'm guessing the basic [theoretical] concept of the sensors on the induced draft motors of today use the same principles of those original "transistors". But are probably much less sensitive, much more cost effective, and could never measure the heart beat of a fly.
    But, you have to admit, it is very interesting when our scientists/researchers take things like this to the extreme.
  12. Likes CEAS-AC-TECH liked this post.
  13. #10
    edmonds wa
    Pull the power to inducer while running in heat and verify it shuts down, if it does must be a pressure switch in it somewhere. At the least verify shut down on failed inducer!
    UA Local 32 retired as of Jan 2020
  14. #11
    Nov 2011
    East Side
    are you saying that newer carrier boards didn’t require the sensors, yet the inducer fans were never changed to meet the new board requirements?
    This post is another prime example of needing some model numbers. Not being a dick, just making an observation. Causes a lot of speculation.
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
