Results 1 to 13 of 21
    Jan 2020
    Best HVAC filters
    I read a lot of the thread here before getting our new HVAC installed and appreciate all the knowledge!
    I have a simple (I hope) question: What is the best filter for our HVAC system. It's a TRANE XL16C package unit. We have a single air return in the hallway. (previously a 20X20, but today they came back and made it larger: 20X30)
    I really want something that has a higher MERV and filters odor, too; BUT even moreso I want the best filter to make the new unit run at it's best for us.
    In the past/old unit we've been using the Filtrete Odor Reduction.
    edmonds wa
    What does your installing contractor advise?
    UA Local 32 retired as of Jan 2020
    Jun 2014
    Dover, DE
    The air filters purpose isn’t to act as an air cleaner and odor remover for the home. It’s to protect the equipment against dust and debris.
    I havent failed. Ive just found 10,000 ways that wont work. - Thomas Edison
    Its not whether you get knocked down, its whether you get up. - Vince Lombardi
    Southold, NY
    Quote Originally Posted by pink toaster View Post
    Then you need extra equipment!
    Filtrete Oder Reduction is like Military's Intelligence, doesn't exist.
    SW FL
    It's A TRANE XL16C package unit. We have a single air return in the hallway. (previously a 20X20, but today they came back and made it larger: 20X30)
    = MERV 11 __ Could create excessive dP
    Recommend MERV 8 MAX for 1" pleated filters.
    Maintaining a low electrical load on the blower motor will increase the probability of an extended service life.
    20" x 30" = 600 SQ INCH [ 4.17 Sq Ft ]
    should be able to handle about 1,200 CFM at < ~ 0.16"
    _______________________ 300 FPM ___
    IF dP is not consistently < 0.16", then 4" or 5" thick is necessary.
    How does that actually works within your # [?] TON system
    depends on The XL16C Blower and THE DETAILS of the duct layout.
    _ _ _ ACCA MANUAL D = EVALUATION PROCEDURE
    Designer Dan
    Oct 2002
    Plano, TX
    Analogy. Chinese have been wearing paper masks to block diseases lately. Probably is helping but would sure cause problems if they were to run a marathon.
    Point is a piece if cardboard is great at stopping dust odors but sucks at allowing air flow.
    Have your contractor design an adequate airflow system that creates little pressure drop.
    Jan 2020
    Quote Originally Posted by buford View Post
    They put in a glasfloss zl 1"
    Southold, NY
    Just get a simple blue filter. One you can see light thru. That's all the static pressure the system can handle.
    Jan 2020
    and here I thought I had an easy question that wouldn't get a lot of nasty answers since it's the one thing that I assumed homeowners were allowed (REQUIRED) to do with their HVACs....
    Silly me for thinking you all could be nice!
    Southold, NY
    What because you didn't get the answer you wanted? Sorry but the system is not designed for what you want. it can be but costs go up.
    Jan 2020
    You'll notice that while I said I would like odor reducing... in my original thread I also said that I wanted what was best for the system. If that means no odor reducing, so be it.... But everyone, other than you, gave me grief and DIDN'T TELL ME THE BEST FILTER TO GET. Which is really all I need to know: brand, merv, whatever info I need to buy a few filters to have on hand (since I don't think anyone including you guys thinks I need to call the HVAC company every time I need to change my filter.)
    "I really want something that has a higher MERV and filters odor, too; BUT even moreso I want the best filter to make the new unit run at it's best for us."
    Jan 2020
    And yes, truthfully I am upset I didn't get the answer I wanted... which was a simple what's the best filter?
    SW FL
    Confused
    __ MERV 8 MAX.
    __ Most appropriate filter = one where the ESP is maintained < 0.5"
    __________________________ External Static Pressure
    In other words, MERV 10 and > will NOT WORK WELL in nearly all systems.
    Blower motors do not like high pressure ( say, ESP > 0.7" W.C.) environment.
    REALITY CHECK :
    _____ There are several informative responses here.
    ______________ i.e. Post # 3
    It's an Easy Question --
    _________ Resolution is not soo Eazy.
    Designer Dan
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
