Results 1 to 13 of 32
    Jan 2020
    Leaking buried LL lines
    Posted a thread yesterday around 6:30, cannot be found. I added tags, did not know I could not create new one.
    How to best find a leak and repair HVAC Liquid Line in the ground, concrete and walls.
    Oct 2011
    Culver, Oregon (Central OR)
    Quote Originally Posted by Grabbeus View Post
    Install a new one above ground.
    Jan 2020
    Quote Originally Posted by Adlerberts-Protege View Post
    Thanks, but it is a 3 story appt. building I am on the 2nd floor, nothing to go on the outside the building.
    I had it all described in my post last night 6:30, it does not show, maybe I added tags I was not suppose to do.
    I will ask my local the HVAC pros:
    1-What about direct inject leaking savers, does it work?
    2 - What about the leak detecting fluid one can use an electronic sniffer with?
    3 - What about using a freon gas sniffer?
    4 - He, he, what about applying water pressure?
    Grabbeus
    Southold, NY
    Grabbeus
    Usually there a last ditch effort and shortly there after something major fails.
    How did they determine the leaks in the line set?
    Grabbeus
    How would any of that work if the lines are inaccessible? You state in the ground, walls or concrete.
    Jan 2020
    They applied 350 PSI on both lines, the LL line went to 285 in minutes.
    Jan 2020
    I am not so worried about the concrete, more about the ground and walls, one can sniff the laek out I imagine.
    Southold, NY
    If there in concrete they should be sleeved so new can be pulled
    In the wall cut the Sheetrock.
    Jun 2014
    Dover, DE
    Has the lineset been isolated and pressure tested? Are you certain that’s where the leak is?
    I havent failed. Ive just found 10,000 ways that wont work. - Thomas Edison
    Its not whether you get knocked down, its whether you get up. - Vince Lombardi
    "In this house we obey the laws of thermodynamics" - Homer Simpson
    Local 486 Instructor & Service Technician
    Jan 2020
    Thanks, yes, understood!
    Jan 2020
    Yes, pressurized and tested 350 PSI and then 285 on the LL line shortly.
    I do not know where the leak is yet
    Emerald Coast
    How long has the copper been buried?
    Do not attempt vast projects with
    half vast experience and ideas.
    Did it continue to leak or stabilize at 285psig?
    Quote Originally Posted by Sleuth View Post
    Very good point!!! Copper will deteriorate over time. Even if you repair the leak, another is sure to emerge soon.
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
