1. Yes.
2. Yes.
3. Yes.
Loking for help with a couple questions I have about how my HVAC system is set up. I'm not experiencing any issue(s), but want to make sure its set up as best it can be.
1. I had my HVAC company re-wire the furnace so that the thermostat controls the staging rather than the timer on the furnace. W1 and W2 are now both connected to thermostat and furnace board. They did not change the dip switch settings that would normally control the stage timing with a singe stage thermostat. Does having W1 and W2 connected to thermostat and furnace board override the dip switch timer settings on the furnace board?
2. Cooling Delay is set for Comfort-R. I read in the manual that a jumper should be placed between Y and O on the board. There is no such jumper. Should I have them back out to add the jumper?
3. I had an Aprilaire 600 series humidifier installed. It is being controled by the Aprilaire automatic humidifier control model 60. In the furnace manual, there is mention of cutting the B/K jumper on the board. It isn't totally clear to me if this should be cut or not in my circumstance. It is not cut. Is this something I should have them back out to look at or leave as is?
Equipment:
60,000 BTU Trane XV95 furnace
2 Ton Trane XR13 Air conditioner
Aprilaire 600 series humidifer with model 60 contoller
Honeywell T9 Thermostat
1. Yes.
2. Yes.
3. Yes.
The BK terminal has nothing to do with the Aprilaire automatic humidifier. It's for slowing the blower to do DEhumidify on demand with a control that support that feature.
Yes, and thanks.
I’ve got a call into the HVAC company.
Beyond having them out, I just like to learn and understand how and why things work. I read the manual, and noticed things were wired differently. I’m trying to learn more about what the Jumpers I asked about actually do. I think I understand the y - o jumper, but still unclear on the BK.
I’ll ask my local company too, but thought I’d throw it out on the forum.
