Results 14 to 25 of 25
    Southold, NY
    Quote Originally Posted by benze View Post
    No; cold water supply. I had asked that at time of install, but had been advised using hot water for different reasons. I never really validated the answers as they made sense to me at the time.
    • waste of hot water
    • hot water (from tank) contains impurities that would be injected into the air
    • hot water temp not high enough to make an impact on an evaporator pad
    Modifying the supply to the HW line would not be particularly difficult; is it worth making the change? Are the above issues not so critical?
    It could make the difference.
    Aug 2009
    Beatrice, NE
    Here is your solution, I have done it several times but you may have to find a different HVAC guy.
    Have the HVAC guy build a metal fitting that is big enough to mount the humidifier on so it can be moved up or down as needed. One time I built duct work to fit between the studs that I could mount the humidifier on as there was no place on the supply or return and connected it with pipe/flex. You just need someone to think outside the box/duct.
    Quote Originally Posted by BNME8EZ View Post
    I'm not sure I understand; do you by any chance have a picture or sketch that I can show someone? Is this separate ductwork that would be done in parallel to the return?
    SW FL
    R.H. % Setpoints
    Reasonable Setpoints
    https://www.wheatandsons.com/blog/fu...er-set-winter/
    __
    Designer Dan
    Aug 2009
    Beatrice, NE
    Sorry I can't give exact details on an open forum. That is why I said you may need a new guy as it is not rocket science to get air from one duct to another, just in this case it has to go through the humidifier.
    It is not uncommon for people to do things so long that they get tunnel vision on how to do it so they can't see past what they have always done to see what they should do.
    Understood. But if i understand you correctly, the incoming air source would be from the supply plenum through the bypass humidifier then. If so, then theoretically this bypass box could be placed anywhere using flex from the supply?
    But I remember being told that with a bypass humidifier to have proper airflow from the supply, the pipe had to be horizontal; using a flex pipe that had bends in it would restrict air and not be efficient.
    If I have an external box like that, wouldn't that issue remain? How will there be enough airflow through the humidifier? Wouldn't placement still be restricted to the same vertical position to ensure the supply line doesn't have bends?
    Would having an additional 4" round fan on the supply pipe to the humidifier provide any advantage to ensure the airflow is high enough?
    Aug 2009
    Beatrice, NE
    The humidifier is on the back side of the furnace in the picture shown, right. Your making it much more complicated than it is. A good HVAC guy could figure this out in a heartbeat. As far as losing efficiency from lack of air flow from too many bends. Round numbers a 6" pipe will flow 100 CFM through 100 equivalent feet of pipe, an elbow is 10'. However that is only if it is being pushed/pulled from 1 way. Anytime you have bypass the air is getting pushed from one side and pulled from the other drastically changing how much air it will flow.
    Now back to your original problem. As I noted in an earlier post and Dan noted in post 17 you are almost at optimum levels now. As I understand the humidifier doesn't run every time the blower runs only when the elements or oil furnace run is that right? If you have them switch a few wires so it runs with the heat pump you will have enough if not too much since you are getting moisture on the windows now.
    Just a word of caution, too much humidity in a house can push moisture into your walls which will then reach a point cold enough to condense into water causing mold in you walls. So be careful how humid you get it in the house.
    Or go another route and have it activated anytime the fan is on. Then, run the fan continually in heating season.
    And yes, be careful with humidity levels!!!
    Just because your reference humidity readings are showing one thing does not mean that this is what you use.
    Moisture on windows is a telltale sign of too much humidity.
    Cincinnati, Oh
    When I say long bypass I mean make the 6 in pipe long.
    Don't use flex, it restricts air flow due to its design!!!
    You've been told a good bit of BS, by the people you have been talking to. And I'm not referring to anyone posting in this thread.
    Agreed. Which is why I have trouble finding someone I can trust/believe here. Most guys I find are with bigger outfits who primarily want to sell new systems or have preconceived ideas on how to fix things and don't know how to think out of the box.
    I finally found someone reliable for A/C but he doesn't do residential HVAC, he'll only do AC service calls.
    Hence why I turn to this site to verify/validate so that at least I can have some better understanding of the systems in place.
Tags for this Thread
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
