Results 1 to 13 of 16
    Nov 2018
    Saudi Arabia
    Chilled water leak
    Dears
    I have leak in chilled water leak in network. Observed consumption of make up water 60 l/hr.
    Didn't found leak by visual inspection of pump rooms.
    Is there any way to find leak area?
    Sent from my INE-LX1r using Tapatalk
    edmonds wa
    Air bleeders piped to drains?
    UA Local 32 retired as of Jan 2020
    Feb 2017
    New York
    Cracked U bend in a coil? Are the condensate drains plumbed right over a floor drain?
    Sent from my SM-G935U using Tapatalk
    -----Stop, step back, relax and have another go at it.-----
    Feb 2016
    Louisburg Kansas
    If you have them I would start with checking the automatic air bleeders. You can walk the pipe at the same time. Then go to the coils.
    Thomas Jefferson
    ottawa canada
    Failed plate heat exchanger that has secondary pressure lower than chilled water loop pressure .
    Jan 2010
    Sea to Sky
    Quote Originally Posted by Healey Nut View Post
    I will put my money on this option.....let it ride.
    Sent from my SM-G965W using Tapatalk
    Nov 2011
    East Side
    Quote Originally Posted by BALloyd View Post
    Except that the OP says he confirmed there are no leaks by visually inspecting the pump rooms.
    With commercial work, Many times, the problem doesn’t exist in the room with the problem.
    I can walk into a building with 100 VAV boxes, and look in the mechanical room, and determine there’s no leak in that room.....doesn’t mean there aren’t any leaks out in the other 10,000 feet of piping.
    Jan 2010
    Sea to Sky
    Pretty sure Healy was implying an internal leak to the lower pressure side. This would not be visually apparent.
    Quote Originally Posted by 71CHOPS View Post
    ottawa canada
    See .........someone gets it round here .
    Feb 2016
    Louisburg Kansas
    Have you noticed an increase in water volume in the lower pressure system?
    Thomas Jefferson
    Nov 2018
    Saudi Arabia
    Quote Originally Posted by WAYNE3298 View Post
    Make up water is increasing by 50 l/h
    Nov 2011
    East Side
    Yes, I was being facetious. If that were the case, the leak would be visually apparent, but he would still be required to leave the room to find it! LOL!
    Jan 2020
    SAudi Arabia
    Most of asset inside bathroom which have drain
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
