Results 1 to 9 of 9
    Nov 2018
    Saudi Arabia
    Chilled water leak
    Dears
    I have leak in chilled water leak in network. Observed consumption of make up water 60 l/hr.
    Didn't found leak by visual inspection of pump rooms.
    Is there any way to find leak area?
    Sent from my INE-LX1r using Tapatalk
    Southold, NY
    Everywhere the chilled water goes.
    Nov 2018
    Saudi Arabia
    We have 22 buildings but make is installed at one place
    Use an IR imager to search for cold spots where the lines are under ground.
    Southold, NY
    Quote Originally Posted by Javed Shaikh View Post
    Isolate each building until the refill slows.
    Nov 2018
    Saudi Arabia
    Thnx will try with this tomorrow
    Oct 2016
    Clearwater, Florida
    We've used infrared imaging to locate hot water leaks before.
    I'm sure it could work for chilled as well, look for the cold spot.
    look for excessive water running out of condensate drains on a/h units if they are bigger units.
  9. Likes heatingman liked this post.
  10. #9
    Chicago area
    Quote Originally Posted by poppa View Post
    Coils would be my first place to start aswell.
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
