+ Reply to Thread
Results 1 to 11 of 11
Thread: Not enough vacuum for pressure switch
    Apr 2006
    Delano, MN 55328
    I have a commercial building with 4 Goodman Furnaces and 2 of them are not able to close the pressure switch that comes of the condensate collector on the secondary heat exchanger. I cleaned all the lines--no pluggs but still is measuring below the vacuum needed to close the switch.
    Can this be anything other then a plugged exchanger??
    Denver, CO
    If it's reading differential pressure do you have the correct differential between the high and low side? Have you checked the flue and intake for obstructions? If you put a manometer on it and it's with in range and still not closing the switch then you have a bad switch.
    Apr 2006
    Delano, MN 55328
    Vents were checked an well with in the lengths. I did check with a manometer and I am right at the the limit of-.4 which is the rating on the switch.
    Check the heat exchangers.
    Mar 2015
    Medford, N.Y.
    Check the inducer squirrel cage wheel.
    Apr 2019
    central MN
    the rating on the switch is the point it reopens not the point it closes. you do not have enough vacuum. have you ensured that the inducer assembly is clear? are the ports to the pressure switch clear of debris? I did not see an answer if the venting was inspected for clogs, bugs, standing water, etc. just a statement that the length was correct. how long are the venting runs? what size is the vent pipe? how many 45s and 90s on vent and intake. what is the model of the furnaces?
    Jul 2012
    WA
    Pull the inducer to inspect it and take a look at the secondary heat exchanger.
    Aug 2010
    Living for the Lord
    Just had one, that I found a wasps nest about the size of a silver dollar. Wasn't dropping out on low vacuum, but tripping out on the flue temp sensor.
    It doesn't take much, to obstruct the air flow.
    Sent from The Lions Lair
    "If you can’t describe what you are doing as a process, you don’t know what you are doing." ~ W. Edwards Deming
    All those who wander..are not lost.
    Do NOT..mistake my kindness for weakness.
    The early bird may get the worm..but the second mouse gets the cheese.
    Virginia
    Quote Originally Posted by bow hunter View Post
    I have a commercial building with 4 Goodman Furnaces............
    Are they all the same model?
    To second what "JmanHVAC" said - what is the model number of these units?
    Apr 2019
    central MN
    Quote Originally Posted by Red Man View Post
    I just had a unit with the same issue. I pulled the inducer assembly to check the secondary and a dead mouse fell out of the inducer wheel, problem solved
    Apr 2019
    central MN
    where did OP go? We would love to know what was found as the problem.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
