Results 1 to 7 of 7
    May 2008
    Luanda Angola as my base but working in Africa
    help needed chilled water system 2 trane RTAC 275
    Hi Guys ,
    I m doing a maintenance in a building and need to change the expansion tank the one which is installed is 750 L now i could not find that size only the 500 or the 1000 liter what do you think which one should we apply.
    Thanks in advance for your help.
    Feb 2016
    Louisburg Kansas
    If you can't get a direct replacement go for the 1000 L.
    Thomas Jefferson
    May 2018
    VA/DC
    what wayne said
    May 2008
    Thanks guys that was what I thought but needed second opinion.
    Sent from my K10 using Tapatalk
    Dec 2014
    2 500s?
    Good time to check sizing and see what it really needs.
    Sent from my SM-G950U using Tapatalk
    edmonds wa
    What maintenance would lead you to replace tank? Most larger ones have bladders that can be replaced, if needed.
    UA Local 32 retired as of Jan 2020
    May 2020
    In this York heat pump reviews we also include the York LX models. See the table below for a comparison index from the Affinity™. LX for York is considered the economy models but they have several different types with different efficiency levels.
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
