    Jan 2020
    Question Thermostat defaulting to set up mode, not keeping time
    Hello,
    I have a Carrier furnace TP-PAC01. Recently the thermostat is constantly displaying the set up mode. Usually the set up mode only displays when you open the little door to access the control buttons. When I do open and close the door it will display normally for a while but always reverts to set up.
    It has also not been keeping time, which all my reading says is an issue with over heating. Looking at the furnace itself the LED light is not displaying any error codes, just solid yellow. I replaced the air filter, which was dirty (second time in 12 months), but that hasnt changed anything.
    The set up mode and lack of error code in addition to the time issue make me think it may not be overheating, but i really cant tell. Does anyone have an idea about what this might be? I have been in touch with a pro but after there was no LED error code he suggested i post here first.
    Thanks for your help!
    Kevin
    Quote Originally Posted by Kgreen03 View Post
    Hello,
    Kevin
    That is the thermostat, NOT the furnace!!
    What filter are you using? If it is a 1" wide filter, it should be replaced far more often than that!!!
    Jan 2020
    Thanks for the reply
    Quote Originally Posted by pacnw View Post
    Thanks for the reply, ill start by replacing the thermostat and see if that solves the issue.
    Its a larger filter, about 4 or 5 inches wide.
    Athens, Ohio
    Thats guessing, not diagnosing. You could replace lots of parts and never find a solution.
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
    The model number you provided is for the thermostat NOT the furnace.
    I was not saying the issue is the thermostat, it usually is NOT the thermostat!
    Cincinnati, Oh
    Wow, really took your advice the wrong way!
    "Just get it done son."
    Dad adjusted
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
