+ Reply to Thread
Thread: Heat pump amperage
    Jan 2020
    Mid-coast Maine
    Question Heat pump amperage
    I am new to the heat pump design and operation.
    On the engineering data for a Mitsibushi MXZ-3030NAHZ2 it shows a graph where as the temperature went down the amps decreased from about 5 at 65 degrees down to 3.2 at 5 degrees. This seems counter intuitive - can some one educate me?
    ....and what kind of webinar or virtual event is this???
    Jan 2020
    Portland Oregon
    It seems that amperage corresponds to heat absorbed into system & the compression ratio created as a result. There’s much more heat being absorbed by outdoor coil (as evaporator) which has to be rejected by indoor coil (as condenser).
    Jan 2020
    Seattle washington
    Also if this is a Mitsubishi with an inverter compressor its running speed and amp load will vary with heat or cool load similar to a frequency drive.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
