What about air trapped in the line ? Can you manual purge it ?
Km650mah
Water to building was shut off , now the machine beeps one time , and when I do a board reset it will NOT reset
I hold the button for about 10 seconds , and it goes right back to beeping
Ive never seen this before
I read that the thermistor could cause this so I tested the ohms at 3k ambient and 5k when inserted into ice water
Tips book says 500 ohms or less is bad , well 5000 should be ok...
What else would cause a board not wanting to reset?
The machine will Not come on ....
I've tried holding the reset button while turning the machine on
I've tried turning the machine on and immediately pushing the reset button
I've tried holding the button for 5 seconds of tried holding the button for 10 seconds I've tried holding the button for 3 seconds
I verified that it does recognize me pushing the button because the yellow LED stays on while I'm holding the button
Wonder if it starts up with the thermistor unplugged.
Theres a little green corrode in the connector , so im headed to purchase a thermistor
Its very odd how no water upset the computer
With it unplugged does same
That trip took a little while because Hoshi dealer is next to the gun store....
Now im 700.00 poorer
But anyhow , sanded green corroded pins , replaced thermistor , same 1 beep
So i start paying closer attention to the reset button and IF the button indeed works
Not thinking so...
So I fiiddle around pushing button 100 times and wigglin and prying to no avail
So out comes the meter. Without pushing button I find 2 pins ohm out , other 2 pins ohm as well.
Ohm across other way neither side ohms
Push button get same results... Wtf
It must be corroded inside
OK ive had enough , i take my little screwdriver and short 2 pins that didnt ohm out ..... and whaaalaaa it reset
I just got lucky
Oh and got a new Sig ! So all is well
