Results 1 to 13 of 13
    Jan 2020
    No voltage at thermostat but 24 volts on furnace control board ...
    So the thermostat isn't working. Multimeter says no voltage at thermostat. Where the thermostat wires attach to the furnace control board, I get 24 volts. Wire connections are tight. I don't understand how the control board wire connections have power, but 6 feet away at the thermostat the same wires have zero voltage (of course a break in the wires would explain, but the wires haven't been touched).
    Southold, NY
    How are you measuring?
    Maybe call for service!
    What terminals are you measuring/checking?
    External safeties?
    Jan 2020
    On the control board ... one probe of the multi meter stays on R, moving the second probe between all the other connections (white, yellow green blue) I get 24 volts.
    On the wires at the thermostat I get zero.
    Athens, Ohio
    Are you a tech?
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
    Southold, NY
    With 1 lead on R?
    Jan 2020
    Yeah. "R" ... "R" the red power wire.
    Southold, NY
    So
    R to G zero volts?
    What does that tell you?
    Jan 2020
    I can jump the heat on at the furnace control board, but can't jump it on at the thermostat. Bad thermostat wire?
    Oct 2014
    Saint Pail, Minnesota
    Is this a Nest thermostat?
    Southold, NY
    Quote Originally Posted by mr.magoo View Post
    Yes
    No
    Maybe
    I agree with is this a NEST?
    Jan 2020
    Not a NEST. A 10 - 15 year old Trane programmable thermostat.
    https://hvac-talk.com/vbb/showthread...ad-these-rules
    2. Do-It-Yourself (DIY) - not here.
    This site is for industry professionals and folks seeking HVAC/R advice and knowledge. Please do not ask for step by step instructions on purchasing, installing or repairing your own equipment. This is our job and our livelihood. We are generous, but not to a fault.
    Questions of this type will not be answered and may be deleted at the discretion of the Moderators.
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
