Results 1 to 6 of 6
    Jan 2020
    Standalone UA 98H dehumidifier w/fresh air baffle
    Hi all,
    Considering a UA 98H dehumidifier with fresh air baffle as a stand-alone system for a basement. Would love any experiences youve had.
    Also, can you split the 10 (in house) Intake into 2 returns? My thought is to utilize the fresh air intake, and have 2 returns on opposite ends of the basement, then dump the conditioned air in a centralized location. In my mind that would create a somewhat uniform cycle.
    Or, if a single intake is on one of the basement is it capable of pulling moisture from 50 away while passing through a den and storage room?
    Thanks so much for any input.
    Southold, NY
    Quote Originally Posted by josh84ellis View Post
    Hi all,
    What does the installing contractor say?
    Jan 2020
    At this point he has suggested mini splits. But he also expressed concern that it would be easy to oversize the space. It is the same installer that did my heat pump upstairs. Hes been in the basement before but its been a while. Hes going to come by soon and give it another look. Problem is were good friends so I feel a bit obligated to use him but I want to be sure weve explored all options.
    Southold, NY
    Hes correct in Its easy to oversized this space!
    Madison, WI/Cape Coral, FL
    I think we covered this another post.
    Regards Teddy Bear
    Jan 2020
    Regards Teddy Bear
    I replied to the wrong post. At this point I havent discussed the details with him. He knows I want/need one but was sort of leaving that up to me depending on how much I want to spend.
