Results 1 to 7 of 7
    Jan 2020
    No led light and furnace shutting down
    Hi, so a 4 year old Armstrong air model a93 converted to propane is just starting to give an issue. Furnace won't start up, had to reset the main breaker and it started up. But ran for about 15 mins than off again without reaching the normal room temp. It's still about 7 degrees Celsius from t stat set point. The led light that gives off the normal status or code status is not lit up at all. I've bypassed the t stat to confirm the nest t-stat isn't malfunctioning. I did just change the air filter. Also to note, it's the coldest days of the year so far here at around - 40 Celsius. This issue just started today.
    Southold, NY
    Not a fan of NEST
    It tripping on a safety
    Call for service.
    Quote Originally Posted by Oilersman View Post
    Usually that light should be on steady or blinking.
    If it's blinking, at what rate?
    Is it blinking a fault code?
    If it's off, then I would think issue is outside the furnace. Again, usually speaking.
    If any of these are confusing or not understood, time to call for service.
    I, too, highly dislike NEST stats!!!! They create too many issues.
    Athens, Ohio
    Did you take the plastic wrapper off the filter? It has happened?
    And Nest is a terrible thermostat.
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
    Jan 2020
    No led light is present at all. After changing the air filter the furnace has been great all day. Any good alternate t stats as opposed to the nest? I like the wireless and internet connectivity of it. Thx.
    Jun 2014
    Dover, DE
    What filter are you using and how dirty was it?
    I havent failed. Ive just found 10,000 ways that wont work. - Thomas Edison
    Its not whether you get knocked down, its whether you get up. - Vince Lombardi
    Jan 2019
    Vero Beach, Florida
    Quote Originally Posted by rider77 View Post
    I bet it was a FILTRETE
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
