    Jan 2020
    Damper Motor issue
    Hi,
    My Heater has a Damper motor which is for fresh air.
    This damper is for fresh air vent. And the brand is: Cramer Company 24VAC 60Hz (No: 140124)
    Pl. find attached images.
    It is making some noise and I was told by the AC & Heater maintenance guy to replace it. He is quoting around $/-
    I was checking prices on the damper motor and it round $/-
    I am thinking it should be fairly easy to replace it after looking some videos on youtube
    Now the question is how can I find out which damper motor I should buy? Also, should I just buy damper motor or the whole damper housing and actuator?
    I appreciate the suggestion.
    Thank you
    RajeshC
    edmonds wa
    May be cheaper just to buy the whole assem, expose the duct work where it connects to, verify size, and turn off the power to it when replacing. It sounds like the gears inside maybe trashed, pull the motor off, then you can tell is it the motor or is the damper blade jammed up.
    UA Local 32 retired as of Jan 2020
    Jan 2020
    Quote Originally Posted by buford View Post
    May be cheaper just to buy the whole assem, expose the ductwork where it connects to, verify size, and turn off the power to it when replacing. It sounds like the gears inside maybe trashed, pull the motor off, then you can tell is it the motor or is the damper blade jammed up.
    Thank you, Buford. I am having the challenge to know what it is called to buy. Is it Damper Housing, Damper, and Actuator? What is that I need to search and find to buy? Any guidance is appreciated?
    Thank you
    RajeshC
    Southold, NY
    Quote Originally Posted by chraj View Post
    Thank you
    RajeshC
    Leave it up to your service provider
    Jan 2020
    Thank you.
    The service provider is quoting $/- Is it reasonable for this work?
    Southold, NY
    Thank you.
    The service provider is quoting $***/- Is it reasonable for this work?
    Pricing is not allowed.
    I would get more!
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
