Page 7 of 8 FirstFirst 12345678 LastLast
Results 79 to 91 of 102
  1. #79
    May 2014
    Bay Area California
    Oh, here's the thread I lost. Looking for another thread. Just so I could make a point.
    Bottom line, you want to turn this into a test question for others?
    Post it on this thread:
    https://hvac-talk.com/vbb/showthread...Test-Questions
    Quote Originally Posted by BBeerme View Post
    Oh. I just got that. I was likely speed reading before.
    You pulled a funny. And yes, that is funny !!
    Maybe I'll use that as a test question for the guys I work with. Or new hires; yeah, that might be better.
    I had a thread on here with all sorts of bogus test questions, but I think it got lost when this site's server crashed. It was three pages of hilarious questions. Questions that only a senior tech would be able to see through. Wonder if that thread is still around?
  2. #80
    Dec 2018
    SW-ARK
    We bleed through while brazing, we raise pressures equally, and we test to near 200. If pressure doesn't hold we soap bubble and listen with an amprobe.
  3. #81
    May 2018
    FLORIDA
    Quote Originally Posted by DuskEnough View Post
    Thats what i do but we raise the pressure at 250 and use H10 PRO for eventual leak search LOL
    Great mind think a like
    Visit our website at www.airconcomfortcooling.com
  4. #82
    Jun 2019
    agreed. You are just asking for problems if you start going higher......problems you do not want.
  5. #83
    Jun 2014
    Dover, DE
    Quote Originally Posted by mtsaz100 View Post
    What problems?
    “I haven’t failed. I’ve just found 10,000 ways that won’t work.” - Thomas Edison
    “It’s not whether you get knocked down, it’s whether you get up.” - Vince Lombardi
    "In this house we obey the laws of thermodynamics" - Homer Simpson
    Local 486 Instructor & Service Technician
  6. #84
    Jan 2010
    Quote Originally Posted by rider77 View Post
    What problems?
    Running out of nitrogen sooner
  7. Likes DuskEnough liked this post.
  8. #85
    Jul 2019
    Oklahoma home its in the name
    It seems to me that not testing to normal operating pressure would be asking for problems.
    Sent from my "smart" phone using Tapatalk
  9. #86
    Aug 2018
    Piedmont Triad, NC
    So, we had an install class at bakers last week and I asked the guy what pressure to test at. His official slide said the stock standard “set nitrogen relief valve to 150” but he said just don’t exceed what the low side equipment plate says. Makes sense to me.
  10. #87
    Mar 2016
    NY
    Before I switched companies I would always pressurize to “running condition”, always put the pressure in my wo summaries etc. and at my new company my service manager said never go above the test pressure of the low side. When I’m in doubt, I just read what the manufacturer wants you to test and if they don’t spec it look for the low side test pressure. Just my
    With this said, I have witnessed leaks with higher pressure vs lower pressure and vise versa. For instants I had a unit hold 100psi but when bumped to 200 found a leak. Also had a unit at 250 not show a leak until I reduced down to 100psi. So what I usually do is if I have a known leaker, if I can’t find it I slowly increase pressure if possible
    “Happiness can be found, even in the darkest of times, if one only remembers to turn on the light.”
  11. #88
    Aug 2008
    Las Vegas NV
    On new installs I only test @ about 200#. Looking for a leak, I creep it up to whatever it takes (never needed 600# though).
    Straight cool systems 600# will exceed the rated pressure on the evap coil.
    https://www.allstyle.com/see-our-pro...num-coils.html
  12. #89
    Jan 2010
    Per Mitsubishi specs
  13. #90
    Mar 2016
    Dayton Oh
    But but but..... 250 should be fine. Been doing it that way 75 years.
  14. #91
    Jul 2019
    Has anyone here ever blown anything up from over pressure?
    Or heard of it happening?
    What goes first with over pressure?
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
