Page 2 of 8 FirstFirst 12345678 LastLast
Results 14 to 26 of 102
    Southold, NY
    Quote Originally Posted by AIRCON8 View Post
    i do residential up to 5 tons
    pressure switches txv coils and compressor valve
    no need to go to 600 psi
    not me
    Whats your concern?
    See Step 18:
    https://portal.fujitsugeneral.com/fi...ll%20Guide.pdf
    Dec 2019
    Lake of the Ozarks Mo
    I was trying to find a leak on a 3 head mini split. Finally found it in a flair fitting. It took 400 psi to make it bubble. I left it with 200 psi for 2 days with no change
    Jan 2010
    Quote Originally Posted by HAWK71 View Post
    Case in point.
    May 2018
    FLORIDA
    Nope i'm not going there
    period LOL
    400 psi too much it will leak at 200 and with a good leak detector you'll find it.
    Visit our website at www.airconcomfortcooling.com
    Jun 2014
    Dover, DE
    period LOL
    No, not really.
    I’ve seen many systems where the leak only showed up at a higher pressure, say over 350-400 PSI.
    Most minis and all VRF now require ~600 PSI standing presssure for 24 hours.
    I havent failed. Ive just found 10,000 ways that wont work. - Thomas Edison
    Its not whether you get knocked down, its whether you get up. - Vince Lombardi
    "In this house we obey the laws of thermodynamics" - Homer Simpson
    Local 486 Instructor & Service Technician
    Cincinnati, Oh
    Quote Originally Posted by rider77 View Post
    No, not really.
    Agreed, and its not even recent.
    I remember reading about it for fujitsu 10 years ago.
    "Just get it done son."
    Dad adjusted
    May 2018
    FLORIDA
    everybody talking about mini split and VRF
    can you imagine 600 psi on a York micro channel coil ?
    they leak just if you look at them LOL
    Jun 2014
    Dover, DE
    Still need to test conventional equipment at pressures similar to those it will be exposed to while operating.
    Now that said watching the micron level during evac will be the true end test, but 250 psi test pressure on equipment capable of over 400 psi during normal operation is a bit too low.
    Southold, NY
    B S
    What's the difference between 600 #'s N2 and 650 R-410A with a bad cond fan, overcharged Heat Pump?
    May 2018
    FLORIDA
    Still not going there
    250 psi its my limit period LOL
    Southold, NY
    So you don't follow Manufactures Recommendations and Best Industry Practice's.
    Jun 2014
    Dover, DE
    Why?
    May 2018
    FLORIDA
    exactly
    250 and triple vacuum
    that's it
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
