    Jan 2020
    Basement returns and radon
    My unfinished basement has a radon problem. There isn't enough air movement under the slab for an under-slab depressurization unit, so I had an ERV installed. The radon levels haven't gone down far enough, and my radon mitigation contractor says the problem is that in my unfinished basement room there is a large return and only a small supply for my HVAC system. They believe that this is creating a negative pressure in the basement, effectively pulling more radon through the slab and walls. They are recommending that I have an HVAC contractor remove this return. I've tried to find a definitive answer online as to whether a return in a basement can increase radon levels, but I can't find one. I am hoping this community can provide some informed opinions on this.
    Quote Originally Posted by BigData View Post
    Blue highlight portion;
    Isn't that why they install a powered unit?
    Red highlighted portion;
    Who suggested that would do anything for radon? If it was your radon contractor(not knowing much about radon removal) I would look for another contractor!
    edmonds wa
    How did you come up with a radon issue? Using one of those monitors you can send in for testing or is it a problem in your area? Curious.
    UA Local 32 retired as of Jan 2020
Tags for this Thread
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
