Results 1 to 13 of 19
    Dec 2019
    Duct Noise - What Can I Do?
    Hi,
    I have an oil canning/pinging noise coming from one end of my duct work. The noise is under the master bedroom and I can it hear it all night and I'm actually losing sleep because of the noise.
    Is there any solutions to fix this? Does it have to do with the duct hanger?
    I was thinking of getting some metal strapping, press in the duct work and screw in strap to brace it. Then insulate the duct around this area.
    Dec 2019
    Here is the sound.
    https: //youtu.be/MLBb55TOqBo
    Southold, NY
    New construction, Old Construction? Are the ducts accessible?
    Dec 2019
    Old construction. House built in 2000. Ducts are accessible, unfinished basement.
    Jul 2000
    Northern Wisconsin
    That sounds like expansion noises. More than likely some part of the metal is rubbing up against wood as it heats and cools (grows and shrinks) and making the noise as it slides past a certain point.
    Dec 2019
    Quote Originally Posted by firecontrol View Post
    Thanks for reply. There isn't any metal touching wood. The duct work is hanging about an inch lower than the floor joist.
    I agree, not oil canning.
    Dec 2019
    What is the best method to fix it? Insulation?
    I've added two photos (not sure why they rotated when I uploaded it).
    Dec 2019
    Any suggestions?
    Dec 2019
    Anything to stop the noise?
    Jul 2000
    Northern Wisconsin
    Until you identify where exactly the noise is coming from there is no way to know how to stop it. Each type of problem requires it's own kind of solution. Spend the time and locate the reason/location/material like I would have to if called to your home.
    Dec 2019
    I found the location. If I press on the duct hanger, it stops. I guess I will try adding a screw.
    https://youtu.be/MLBb55TOqBo
    or loosen the screw or give it (the duct) a sharp kick/bump
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
