Results 1 to 13 of 14
    Dec 2019
    Confused 24 VAC to 0-10VDC device
    Hi Everyone,
    New to the forum thought this would be a great website to post this question.
    I have a 24 VAC thermostat I need to control 0-10 VDC actuators with. Does anyone know a reliable device that will accomplish this? I don't need to modulate the actuators just open and close them.
    Thanks in advance.
    FYI any Inncom related questions I'm your man.
    Nov 2018
    Los Angeles, CA
    You might check with the manufacturer and see if a 24 vac signal will open the actuator. I know that Belimo has some that would.
    May 2018
    VA/DC
    honeywell makes a stat that has 0-10 an 4-20 outputs. The ones i had at a site did the hot and chilled water valves.
    its a starting point to look at
    For your application.
    Can you take a standard 24 v output and make it modulate, no. is there some conversion board, you can look. But youre better off getting a 24v power open spring closed, or a floating actuator using a relay to make it open closed only.
    Dec 2006
    What? Who? Where?
    As stated by mitch if you apply 24vac to the 0-10VDC terminal/wire on a Belimo it will drive full stroke, remove the 24vac and it will return to the original position. Or you can install a 10vdc power supply (or either 12vdc or 9vdc battery) and switch that (if thermostats contacts are relays and not triacs) to drive the actuator to 100% (90% if using 9vdc battery).
    kontrol out
    "Good" - Jocko
    "Open is as open does." - Forrest Gump
    "Can't we all just get a Lon?" - Garry Jack
    "BACnet: integration or interrogation?" - The Janitor
    "Interoperability? You can't handle interoperability!" - Nathan R. Jessup
    “What’s that? Aaa… open protocols? Don’t talk about…. open protocols? Are you kidding me? Open protocols? I just hope we can hardwire an interface!” - Jim Mora Watch it here!
    Jul 2018
    Wisconsin
    Honeywell TB7980B1005
    Dec 2014
    GA
    there are fan coil unit thermostats that will do the trick.
    http://www.viconics.com/DATA/TEXTEDO...00-PIR-E03.pdf
    Dec 2019
    Are they spring return actuators? If so just configure it to open with 0 volt dc signal. Then switch 24 on it will open full, remove 24 will spring closed.
    Jun 2016
    Saavannah GA
    If it doesn't need to modulate then its easy. I would use a 24v relay (you may need a 24vac transformer to supply the t-stat) and 10vdc power supply just to isolate the two systems. When the t-Stat calls for (whatever) 24vac power is applied to the relay coil, then the NO relay relay contact closes supplying 10vdc to the actuator.
    Jul 2002
    I've actually used a bridge rectifier and voltage halfer before.
    Aug 2008
    Hibbing, MN
    If God didn't want us to eat animals... He wouldn't have made them out of MEAT.
    Dec 2008
    Seattle WA
    Quote Originally Posted by Tyrell View Post
    Hi Everyone,
    Thanks in advance.
    If it's a Belimo actuator, there is a way to wire it so it will act like a two-position actuator, with no added devices required. Check with your belimo rep, they should be able to help you out.
    Oct 2011
    Chicagoland Area
    Quote Originally Posted by JohnLoves2ski View Post
    https://www.belimo.us/support/Produc...on-control.htm
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
