Results 1 to 13 of 32
    Aug 2016
    Infinite switch Crown Verity Steam table
    This is a 208 v, hot dog steam well with ambient exposed element which sits underneath a stainless steel pan filled with water to steam the hot dogs, controlled by infinite switches.
    I replaced a 240v, 15 amp(3750 watts) infinite switch with one I had in the truck that is 208v, 13 amp, putting the wattage at 2704. The element wattage is 1750(see pic). The element only pulls about 8 amps.
    I do know that the switch has to be capable of handling the wattage in order for the bimetal to stay closed longer and get to the proper temperature.
    I turned the new switch to the highest regulated position at 7 on the dial and it shuts off the indicator light in 30 seconds. This new switch is only working on high setting which is continuously passing voltage to the element.
    What am I doing wrong here?
    1st pic: old switch
    2nd pic: new switch
    3rd pic: element
Size:  324.8 KBName:  208.jpg
Size:  41.2 KBName:  element.jpg
    Jan 2010
    Are you saying at the number 1 position you're not pulling amps ?
    Aug 2016
    At number 1, no amps, it starts to come on at about number 4, but cuts out in a couple seconds and takes a very long time to come back on. So I set it to 7 and it does the same thing. I am thinking it has something to do with the lower voltage and amp rating even though it seems like I got the wattage covered
    Jan 2010
    Was the old switch the factory original ?
    Aug 2016
    yes it was. But that switch is so unreliable. I have probably changed that switch 2 times in the past year, so I decided not to order that exact switch again and possibly order a different one with similar ratings, but it was an emergency so i put what I had in.
    Aug 2016
    The specs say unit is 240 but its getting only 208v. Thats how its always been
    Jan 2010
    Which switch did you replace left / right or middle ?
    Aug 2016
    Left switch, the larger element rated 1750 watts
    Jan 2010
    But even at 208 volts it's still only 10.09 amps.
    Jul 2002
    SE Texas
    First, I suggest using OEM parts when repairing appliances. Second, OHMs Law is your friend.
    With your chrome heart shining in the sun, long may you run.
    Aug 2016
    Quote Originally Posted by SandShark View Post
    as you see in this thread, both vtp99 and I have been using ohms law but its not yielding answers we need. it does not make sense why a 13 amp switch cannot stay closed long enough on any cycle setting when the heater is only pulling a max of 10 amps.
    perhaps these switches need to be rated much higher to control smaller loads( original switch was 15 amps 240 v much higher wattage)
    Jan 2010
    It will be interesting to see if it changes using the higher voltage.
    Even if it's not the original OEM.
    Jul 2002
    SE Texas
    Doesn't the infinite switch have an internal bi-metal switch in series with the heating element that breaks the connection to the heating element? In the OEM infinite switch, isn't that bi-metal switch rated for 240V? Think about it.
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
