Results 1 to 9 of 9
    Jul 2019
    Now that's craftsmanship
    Not that big of deal, but... Why? There was plenty of other ways to make it so the ball valves don't hit each other. And obviously it wasn't a diy since they used propress.
    Jan 2010
    Sea to Sky
    Those handles are not reversible if you take one off????
    Sent from my SM-G965W using Tapatalk
    Jan 2012
    Broomall, PA
    You have to close the vertical one first. I would take the handle off of the horizontal and bend it into a U, or a 45
    If I do a job in 30 minutes it's because I spent 30 years learning how to do that in 30 minutes. You owe me for the years, not the minutes.
    Jan 2014
    New England
    Dang! can’t even shut off the disconnect switch and hitting the pipe...geez only kidding
    Can you at least fully open the disconnect box?
    Oct 2008
    Quote Originally Posted by BALloyd View Post
    Never seen one that was.
    A little bend of each handle would facilitate each valve's operation, but I've also always been critical of such crap work.
    "You never know what others don't know." -
    If I can't laugh at myself...then I'll laugh at YOU! -
    this is poor work for sure it would be red tagged in my area to close to the disconnect box they would make us re route the piping away from it
    Sep 2019
    Northern Ontario
    The valves I have dealt with, you can reverse them like you stated. But some times you have to bend the tabs on the handle, which removes the stop and you will be able to over rotate the handle.
    Madison, Wisconsin
    Lot of guys out there with access to tools they should not be operating... Apartment maintenance guys come to mind....
    I r the king of the world!...or at least I get to stand on the roof and look down on the rest of yall
    i did apartment maintance but i knew when to say sorry this is not a job i can handle or do call a pro
Contracting Business
HPAC Engineering
EC&M
CONTRACTOR
