I don't understand. That looks like the pre-charged line set. Not much else you can do the the extra.
I did not know they made them anymore.
So one is blowing hot air into the economizer, the other is against a wall. Damn fly by nighters.
Can someone please explain to me -
Why is there never enough time to do it right the first time, but plenty of time to do it twice?
Please view site rules: http://hvac-talk.com/vbb/showthread.php?t=1241
Apply for Pro Membership: http://hvac-talk.com/vbb/showthread.php?t=116113
Not a fan of that either, pretty much takes out needing a professional to install equipment. That pretty much means the pro that should have got the job, is going to have to deal with a clusterf@#k through the entire life of the system.
However, I was pointing out that the installers should have turned the units 180 degrees around, so a tech can work from the service end with no obstruction. Looks like they were cheaping out on the couple of extra feet of sealtite and wiring.
Why is it that those who complain the most contribute the least?
MONEY CAN'T BUY HAPPINESS. POVERTY CAN'T BUY ANYTHING
What is the issue? Looks like a good heat reclaim set up going into the economize in the winter for some free heat and a good artificial heat load for the oversized AC in the summer to keep it running for dehumidification. LMAO
Sent from my SM-G965W using Tapatalk
