Results 1 to 9 of 9
    Dec 2018
    Ventura, CA
    splice a cap tube?
    Replacing the evaporator coil on a reach in cooler and the last foot or so of the cap tube broke off. Given the hassle in replacing the entire cap tube, any acceptable way to re attach or splice on a new section?
    Jan 2010
    Reconnect the two halves with the next size up tubing.
    May 2014
    Bay Area California
    Yeah, done it a few times myself, everything worked fine afterwards.
    If you were a real tech, you'd solder a relay on that board and call it good to go.
    I do a triple evac with nitro to remove non condensables.
    I use 56% silver on everything except steel.
    Did you really need the " If you were a real tech " ??
    Apr 2003
    Maple Grove, MN
    Get yourself a micro flare block and swedging kit. I'm just kidding, well at least I think I'm kidding. I have also had success with using a small chunk of 1/4" or 3/8" tubing (and a Channellocks) to splice a cap tube back together.
    If at First You Don't Succeed, Skydiving Is Not for You.
    Dec 2018
    Ventura, CA
    Quote Originally Posted by ammoniadog View Post
    Great thanks.
    Yeah the smallest I have is 1/4" unless I want to buy a roll of cap tubing just to get a few inches to splice the two together.
    Dec 2018
    Ventura, CA
    Quote Originally Posted by BBeerme View Post
    Thanks. Much obliged.
    Dec 2018
    Ventura, CA
    Thanks for the input. Will do.
    Oct 2011
    Chicagoland Area
    Aug 2009
    Maine
    I carry 3/16 tubing for this. never had a problem.
