Results 1 to 7 of 7
Thread: New Code
    Dec 2019
    Tampa Bay
    New Code
    I have been having estimates to replace my A/C along with all new duck work. One of my contractors bidding on the job mentioned to me that, according to the new code, every bedroom needs to have a return line. Is that true? I am in Tampa Bay.
    SW FL
    RETURN AIR DUCTS from All Bedrooms was first required
    for new construction more than a DECADE ago.
    The problems associated with No Bedroom Return Air path were
    first identified and tested > 18 years ago.
    Use of bedroom return air ducts is Not a " NEW " building code idea.
    Designer Dan
    SW FL
    CURRENT CODE
    Designer Dan
    Dec 2019
    Tampa Bay
    Quote Originally Posted by dan sw fl View Post
    Right now there is only one return duct (18 by 30) in the center of my home. That will change once I get my new system.
    SW FL
    Quote Originally Posted by Thomv47 View Post
    I presume the noted size actually refers The Single Filter Grille.
    18" x 30" = 3.75 sq feet filter
    ________ * 300 FPM
    ________ 1,100 CFM could be handled in many systems
    ________ IF the filter is < MERV 8
    Designer Dan
    Jan 2012
    Missouri, USA
    Also get a bid for a ductless mini split system. Might not need much backup heat in FL.
    Dec 2019
    Tampa Bay
    Yes. It is my only return.
