Results 1 to 13 of 16
    May 2009
    MI
    Screw the service guy
    Saw this on vacation in NC.
    Dec 2009
    At least you would be mostly out of the rain, and the outdoor unit is on the same floor as the evaporator.
    What they should have done, was mount it outboard of the handrail, on the floor above. That way you have the angry customer and their inconvenienced upstairs neighbor.
    May 2014
    Bay Area California
    Just keep a few extra units on site. If one ever stops working, just change it out.
    I do a triple evac with nitro to remove non condensables.
    Jan 2010
    Sea to Sky
    Seen way worse than that.....
    Sent from my SM-G965W using Tapatalk
    Mar 2016
    Dayton Oh
    Why is it always a Diakin. I mean goodman. Ah whoever the heck makes them these days......
    Jan 2010
    6' step ladder vs 32' extension ladder, I'll take that trade any day.
    Aug 2009
    Beatrice, NE
    Well yeah, but they only used 1 line set on the hole (SP intended) job. Matter of fact if the connection stubs on the inside unit were long enough they may not have needed a line set, just direct connection and only 2 joints to leak.
    Southold, NY
    Quote Originally Posted by BNME8EZ View Post
    What about the minimum line set length?
    Aug 2009
    Beatrice, NE
    From the back of the inside unit, through the wall, to the connections on the unit. How much more minimum do you want?
    Or are you talking they need to be at least X feet long. There is no space for extra line unless you wrap it around the fan shroud.
    I really shouldn't post some of this stuff, it may give people bad ideas. And we all know these guys have enough bad ideas of their own.
    May 2014
    Bay Area California
    Back in the day, there was one brand or other of ice machine that required a minimum line set length of something like 25 or 40 feet or whatever. They said to just leave the extra as a flat coil next to the outdoor unit.
    I ended up working with a lot of techs who would comment, what a hack install. Had to explain to them that was per the mfg's spec's. Told them to read the manual.
    Jan 2010
    Lots of precharged line sets out there. 15, 20, 30 ft. long.
    Sure, you could cut them down to fit your job. Lose the precharged gas, weld them in, vacuum them down. Kinda defeats the purpose of using them.
    There were also line sets where the liquid line was the metering device, those you left as is.
    Oct 2011
    Gladstone, Oregon (Portland)
    Yep. No board repairs on those, at least not onsite. Swap it and repair in the shop . With a cold beer in hand.
    Aug 2009
    Beatrice, NE
    Quote Originally Posted by BBeerme View Post
    Lennox A/Cs use to be that way (60's) not so much the suction but the liquid. It was 1/4" or 3/16th" tube and 50ish feet long usually laying above the plenum or laying on the center wall plate. It was the or part of the metering device. Some of those units had a short cap tube inside the condenser just before it exited the cabinet.
