Thread: Mudd FML
    May 2009
    MI
    Mudd FML
    Bumped the boiler fill valve with The relief valve off before flushing the boiler mud out of the system. Only thing I could do is laugh.
    Jan 2012
    Broomall, PA
    Explosive boiler diarrhea.
    What? No selfie? You had to get hit.
    Why so much mud? I wonder if the inlet to the exp tank is all mucked up.
    If I do a job in 30 minutes it's because I spent 30 years learning how to do that in 30 minutes. You owe me for the years, not the minutes.
    May 2009
    MI
    Lmao nope I was to the right. Thank god it was in a paint booth garage
    May 2009
    MI
    Cust had boiler filled with Prestone last year he drained and refilled with cryotek.... well that’s what he said at least....
    Aug 2015
    Buffalo,NY
    That’s honestly impressive. On a serious note with that much mud in the system I’d be looking at flushing everything, starting from scratch and then monitoring it. That’s horrid. Did you check it with a hydrometer to see what kind of freeze protection it had?
    May 2009
    MI
    No just dumped, flushed, and filled with water, going to flush it again in a week, see how it looks, then go with 35% mix
