Page 1 of 5 12345 LastLast
Results 1 to 13 of 55
    Feb 2005
    Florida
    Take a look at this pump configuration
    The pump to the right is new and it draws locked rotor amps when started. If I pull the red hose and let it free flow its runs and draws 4.5 amps.
    Anys thoughts? I hate to condemn a new pump.
    Only thing I changed on the pump before installing was rotate the motor 90 degrees for alignment.
    Jul 2018
    Wisconsin
    Bad starter and only showing when under load?
    Jul 2018
    Wisconsin
    What killed the last one?
    Feb 2005
    Florida
    Quote Originally Posted by Spitz View Post
    New Starter.
    Nov 2011
    East Side
    I can’t tell anything from the pic. What are the vertical items? One a pump, one a heat exchanger? What are the brass parts? Valves, check valves? What is the direction of flow? What is contained within the loop?
    Feb 2005
    Florida
    Quote Originally Posted by 71CHOPS View Post
    Pumps and check valves.
    Two bottom fed pumps and discharges out the 3/4" union.
    Flow to the right.
    Nov 2019
    San Antonio, TX
    If it flows to the right,,,from the left, then you are going against the arrow on that check valve. That is if you are talking about the cameras point of view.
    Nov 2019
    San Antonio, TX
    Click image for larger version.
Name:	Screen Shot 2019-12-04 at 7.06.53 PM.png
ID:	813243 That arrow is pointing to the left from what I can tell.
    Nov 2019
    San Antonio, TX
    Or is that just a fuzzy casting mark?
    Feb 2005
    Florida
    Quote Originally Posted by Fred Raud View Post
    Both check valves are pointed away from the pump discharge.
    Feb 2005
    Florida
    What happens (with all the piping put together) when the left pump runs?
    Is the rotation correct on the new pump?
    PHM
    Quote Originally Posted by jimp View Post
    PHM
    Feb 2005
    Florida
    PHM
    Pumps on the left runs and has correct flow. I even pulled the cover and checked the rotation on the right side pump.
