+ Reply to Thread
Results 1 to 20 of 34
Thread: Ice-O-Matic ICE series
    Dec 2019
    Question Ice-O-Matic ICE series
    Hi guys,
    I have a problem with an Ice-O-Matic ICE series cuber with an air cooled remote condenser.
    Model number is ICE0926HR.
    The ice machine itself works properly but its leaking water to the ice bin. A lot of water. Looks like its coming from the water trough. I only worked on Hoshizaki ice machines before so Im really not familiar with this type.
    Help would be appreciated.
    Thank you.
    Aug 2013
    Omaha
    Im going to give you some shit now...
    If you can work on a hoshi then you can work on an ICE series ice o matic. This is a very very easy issue. Just do some thinking and visual inspections, especially on how the water comes into the machine inside
    Sent from my SM-G975U using Tapatalk
    Dec 2019
    I would say the water float is not closing and its overflowing the water trough.
    I didn't have too much time to spend there but while I was there it didn't leak. Store owner said it was leaking constantly before so they turned off the machine. I saw leak only after the harvest cycle when the machine dropped the ice to the bin and the water splash curtain was open. Now I had a call back that its leaking again..
  4. Likes UmmScott liked this post.
  5. #4
    Aug 2013
    Omaha
    Good. Now, another thing with these machines with a float. If the water pressure is high, that float wont be able to close even if u put a new one on.
    So if the float is leaking by, replace it and make sure the water pressure coming to the machine isnt going over 60psi
  6. #5
    Dec 2019
    Thank you I will take a look at it tomorrow.
  7. #6
    Pearland Texas
    Make sure the machine is level.
  8. Likes UmmScott liked this post.
  9. #7
    On a bull named Foo Manchu
    Sounds like a harvest issue. Also check water curtain switch alignment.
  10. Likes UmmScott liked this post.
  11. #8
    Aug 2009
    Maine
    Why don't you introduce yourself to us?
  12. #9
    Dec 2019
    So I removed and cleaned out the water float and adjusted the water level and checked the water pressure. It was fine last week but now its doing the same thing.
    Any tips?
  13. #10
    Dec 2019
    Quote Originally Posted by lytning View Post
    Hi I posted before but my account was deleted for some reason.
  14. #11
    Mar 2015
    Medford, N.Y.
    What was that inlet water pressure?
  15. #12
    Dec 2019
    It was 80psi but I closed the water valve to 60psi. I know its not the proper way to do it I just wanted to eliminate every possible option.
  16. #13
    Southold, NY
    Southold, NY
    Quote Originally Posted by Majszi View Post
    Closing the valve does nothing
    It needs a water regulating valve
  18. Likes UmmScott liked this post.
  19. #15
    Dec 2019
    Heres the manual.
    I know I checked it several times but couldn't find anything helpful in it. Thanks anyway.
  20. #16
    Dec 2019
    Well the ice machine worked properly before even when the water was fully open.
  21. #17
    Dec 2019
    Here is a picture
    https://imgur.com/sAZnIJq
  22. #18
    Southold, NY
    Read the manual 20 - 60#'s water pressure! They don't just guess at those #'s there tested within that range. If your reading 80 they need a regulator.
    Working and working right are 2 different things.
    Due to high pressure its possible you've worn out the float valve just guessing!
  23. #19
    Southold, NY
  24. #20
    Jan 2010
    It's a simple float, is the water not shutting off ?
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
