Results 14 to 26 of 56
    Aug 2018
    Piedmont Triad, NC
    I haven’t heard of the Low Z function. What is it?
    Quote Originally Posted by timebuilder View Post
    My suggestion is to clip one lead (I use the black lead, from my habits with DC) to COMMON, and I probe around with the red lead.
    This ensures that the voltage is at least present.
    My second level when doing this is to use the Lo Z function, which loads the circuit, causing an increase in the current used to make the reading, and that helps to reveal high resistances in the safety chain.
    I will typically pick a limit and look for voltage. If I have it, I look at the diagram to see where in the chain the voltage I just found is located. If that is the first break point from the board, I continue to check down the circuit to make sure it is never lost, and I find where it returns to the board, at its connector.
    Virginia
    Quote Originally Posted by Achso017 View Post
    Check your email. I sent you a couple pdf's.
    Southold, NY
    Quote Originally Posted by rundawg View Post
    Can I get a copy?
    Jan 2010
    Aug 2018
    Piedmont Triad, NC
    Thank you. But now I have to buy a new meter. So thanks a lot
    Southold, NY
    If your really good maybe Santa will surprise you!
    Aug 2018
    Piedmont Triad, NC
    Thanks. Looks I’ll need to acquire a new tool.
    Southeastern Pa
    Until you get that meter, you can take a contactor and put two jumpers on it. You will not exceed the current capacity of the board, but you can put one lead on common and probe with the other. Every terminal in the safety chain, including both board terminals, should pull in the contactor. If all of them do, then you do not have a limit issue...instead, you have an issue that is causing a limit to open...so it is doing its job.
    Of course, some RTU's have line voltage limit circuits, and this idea is not recommended for that kind of testing. This is only for 24 volt circuits.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  9. Likes TheBaoz liked this post
  10. #22
    Aug 2018
    Piedmont Triad, NC
    If I saw Santa I would definitely be surprised. And if I saw someone in a red suit crawling out of my chimney I can promise you they wouldn’t stay “jolly” for long
  11. #23
    Aug 2018
    Piedmont Triad, NC
    Until you get that meter, you can take a contactor and put two jumpers on it. You will not exceed the current capacity of the board, but you can put one lead on common and probe with the other. Every terminal in the safety chain, including both board terminal, should pull in the contactor. If all of them do, then you do not have a limit issue...instead, you have an issue that is causing a limit to open...so it is doing its job.
    That’s...just...an incredibly great idea. My bank account thanks you as well.
  12. #24
    Virginia
    Can I get a copy?
    Check your inbox.
  13. #25
    Southold, NY
    Check your inbox.
  14. #26
    Oct 2018
    Nc
    Quote Originally Posted by BKHVAC View Post
    Hi. I was called out to work on Armstrong packaged unit pge10B36D075A-9B.
    After closing disconnect the furnace control board receives power, waits approx 20 seconds, and starts the inducer fan motor- without a call for heat. I checked voltage from c-w: 0v. Checked R/O and Hi limit circuit- maintains 27v back to furnace control board. Then checked pressure switch and it remains open until inducer fan kicks on, and then closes. No voltage across pressure switch unless c-w becomes energized and then voltage allowed through pressure switch, across aux switch on fan, and back to board.
    When the board receives power immediately LED flashes twice. The trouble codes are no longer on the furnace but from what i could find online seems to be - System lockout. Failed to detect or sustain flame. However, the gas valve never energizes and no spark is ever attempted.
    I've replaced the control board and removed the flame sensor from the board to see if the fault still exists, and still flashes twice. Any ideas?
    Have you check pressure switch and the tube to see if it have crack/leak? Or maybe check inducer assembly, sometime little crack caused similar issue.
