Results 1 to 12 of 12
    Dec 2019
    Help With Thermostat Problem
    Hi there, I turned the thermostat from heat to cool very quickly, and now the cool just won't start. The temperature is set correctly, and other functions like 'auto - heat' work, just not 'auto - cool'.
    It seems like turning it from heat to cool really quickly caused something to malfunction.
    Is there anything I can do to get it working again?
    The thermostat is one of those older Honeywell analog models.
    It was working perfectly up until now.
    Thanks very much.
    Nov 2019
    San Antonio, TX
    24vac still on red terminal? Did you try jumping red to yellow and green and see what happens?
    Dec 2019
    Sorry Brooke Hill I'm just a homeowner, I need it in layman's terms...Thanks!
    Nov 2019
    San Antonio, TX
    Since I am new here, and there are probably rules on how to post on this issue, I'll default and see how the regular members respond to something like this. It's in my nature to want to tell you to pull out a meter and start checking, but I'll just watch what the other guys tell ya. I am just having a feeling that you might have lost your transformer by the way you are describing it. And if it is fused, maybe that. It is doubtful that you tripped a breaker from the thermostat, but its possible if you cycled the compressor too fast. Good luck!
    Tucson, Arizona
    Most of those Honeywell thermostats have a built in 5 minute delay. Switching quickly from heat to cool will activate the 5 minute timer. Its a safety. Anytime you switch the power off or heat to cool will activate that timer. Itll feel like an hour and a half timer, like waiting on water to boil. If it doesnt restart automatically, its time for a service call to your local HVAC professional.
    There are two ways to do things, Right and Again.
    Nov 2019
    San Antonio, TX
    Quote Originally Posted by shavedneon View Post
    Most of those Honeywell thermostats have a built in 5 minute delay. Switching quickly from heat to cool will activate the 5 minute timer. It’s a safety. Anytime you switch the power off or heat to cool will activate that timer. It’ll feel like an hour and a half timer, like waiting on water to boil. If it doesn’t restart automatically, it’s time for a service call to your local HVAC professional.
    Even the analog ones? Ive never seen the older analog ones with a delay.
    Dec 2019
    I had it on 'auto-cool' today for like 1 hour and nothing happened. It just sucks I may have to pay hundreds to a technician when it was something so simple - I just turned it from heat to cool quickly... When I lift off the cover their is all the wires and mercury, I wonder if there is something I can do to like 'reset' it.
    Nov 2019
    San Antonio, TX
    Do you have a friend who is handy with a meter?
    kansas
    Brooke your correct on backing off on the diy. James you said the other functions work the indoor fan etc. , but the outdoor unit fails to come on? If this the case you still have low voltage, and this unit or tstat have a time delay relay that you probably activated. Leave it off at the stat for 5 minutes then turn it on and wait for 10 minutes. If it doesn’t start cooling you need a tech. This as far as we can go in this diy area good luck
    Tucson, Arizona
    Your thermostat is just a switch. If you had a lamp that didnt work, the switch is the last thing youd check. Would you blame the switch if you turned it on and off quickly? A thermostat really is just a switch, if your unit suddenly stopped working itd be a coincidence, and not the cause. If a bulb burns out when turning a light on, its not because you switched it on too quickly, it was going to break. A good HVAC tech should diagnose the problem, and approach you with options to repair. Could be something simple, could be something major. Its going to need a tech to diagnose. Beyond checking the machine is plugged in and has power, the doors are on and filters are clean, we cant be any help here. If someone goes out and tells you something that sounds preposterous, come back and well shoot straight with you. Good luck, let us know how it goes.
    Mar 2015
    Medford, N.Y.
    Got a HW tsat #? I think your "naming" of the switch settings is a little mis- leading. What do you have for settings on the "system switch"? OFF-HEAT-AUTO-COOL? (4 diff settings)Then the "fan switch" has FAN-ON-AUTO ?. (2 settings).
    It can't be set for "auto-heat or auto-cool".
    Moved to AOP.
    Probably just a coincidence that the A/C stopped working. Time to call in a contractor.
Tags for this Thread
