Results 1 to 7 of 7
    Nov 2019
    Wyoming
    Thermostat Location
    The area is only 900 S.F. but the thermostat is located directly across and 3 feet away from the kitchen oven/range which is used every night and the tenant complaint is cold in all rooms but the thermostat reads 72F and its a good thermostat.I am convinced the thermostat is in the wrong location.
    Southeastern Pa
    Typically, in a forced air system, the stat is located away from other heat sources and the supply diffusers, and near the return air grille.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Nov 2019
    Wyoming
    The return grill is 3 feet below and also directly across from the oven, dishwasher, and clothes dryer.
    Athens, Ohio
    Thermostat location is governed by places NOT to put it - outside wall, kitchen, stairway, in view of the main door, bedroom with a closed door. A dining room is usually a good place. Sometimes too close to the return results in a temperature change at the thermostat when the blower starts running.
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
    Nov 2019
    Wyoming
    with that being said how far is too far from the return grill because I can place it around a corner about 10 feet from the return
    Athens, Ohio
    Quote Originally Posted by AlexCollins View Post
    As long as it's an interior location that is not affected by drafts or heat sources that should be fine.
    Atlanta GA area
    One more thing not mentioned...
    Avoid the sun EVER shining in a window/door and hitting the thermostat, or the back side of the interior wall the stat is opposite from...
    GA-HVAC-Tech
    GA's basic rules of home heating and AC upgrades:
    *Installation is more important than the brand of equipment
    *The duct system keeps the house comfortable; the equipment only heats and cools (and dehumidifies)
    *Cheap is not good, good is not cheap; however expensive is not a guarantee of quality!
    Choose your contractor wisely!
