Results 1 to 13 of 13
    Nov 2019
    los angeles
    Smile aluminum pipe and galvanized connections
    I am a retired handicapped architect and I want to build some structures
    that I can move around. For weight sake I was thinking about using galvanized connections (home depot) and aluminum tubing with a gauge that can be threaded to accept the standard galvanized thread( at Industrial Metal Supply), I could use LPS green for threading the Al.
    I can rent a Rigid threader at HD. What do you think?Thank you,
    Didier
    Virginia
    Aluminum doesnt play well with others..... , so use some No Ox when threading and it will probly be fine
    Nov 2019
    los angeles
    Thank you for your answer. Do you have any suggestion as to what I should use as a semi permanent lubricant so I could disassemble what I would built?
    May 2019
    Central, IL
    The noalox will stop corrosion and Allow disassembly, it is almost like never seaze
    May 2019
    Central, IL
    EDIT: Will thread with regular threading oil.
    Use the noalox during assembly of joints , instead of pipe dope
    there are aluminum pipe threading compounds
    May 2019
    Central, IL
    I stand corrected, upon some research i see special oil.
    I have only threaded a few pieces, used rigid dark oil. Seemed to work ok
    Feb 2016
    Louisburg Kansas
    Flanges would solve all your problems if you can use them.
    Thomas Jefferson
    Southold, NY
    Scaffolding companies make aluminum fittings with set screws
    Feb 2016
    Louisburg Kansas
    Good point pecmsg.
    Thomas Jefferson
    Jan 2010
    Yep
    Jan 2012
    Broomall, PA
    What are you building?
    If I do a job in 30 minutes it's because I spent 30 years learning how to do that in 30 minutes. You owe me for the years, not the minutes.
    Jun 2006
    What are you trying to support? How much weight??
    The aluminum air line materials are pretty strong and the fittings are as well though they are a resin or plastic.
