Results 1 to 10 of 10
    Jul 2019
    Oklahoma home its in the name
    And the poor placement award goes to Heil.
    I had to remove the blower assembly to check this safety. I didn't get as many pictures as I should have but this was the least serviceable furnace I have worked on lately. The fan control and ignition control and most of the wires were crammed in front of everything that I needed to get to to check safeties and such.
    Sent from mars using Tapatalk
    May 2014
    Bay Area California
    You couldn't check the safeties at the wires from a more accessible spot?
    I use 56% silver on everything except steel.
    Did you really need the " If you were a real tech " ??
    Jul 2019
    I checked from the board but then I needed to narrow it down to one and that was the easiest one to get too because I only had to remove the blower.
    May 2019
    Central, IL
    Goodman gets my vote , put in an downflow 80% the other day and blew the low voltage fuse ( rookie mistake I know).
    It took half an hour to disassemble everything and pry the inner door loose due to factory siliconed it all the way around.
    F____k goodman , never again
    Jul 2019
    Oh wow I've never seen that model Goodman.
    Quote Originally Posted by Stoichiometric View Post
    May 2019
    Central, IL
    I dont have the model number , but it was just the lowest end 80%. It had the ecm motor since there out of the psc models now.
    I hope I never see one again, lol
    Jul 2019
    I probably never seen one because downflow is extremely uncommon here.
    Aug 2018
    Piedmont Triad, NC
    Yeah, those are absolute bovine fecal droppings. I should be ashamed to say this, but I can count on one hand how many of those Ive checked the blower cap on PMs. Its bad enough having to adjust blower speed on startup.
    Aug 2018
    Piedmont Triad, NC
    Quote Originally Posted by R600a View Post
    Those things suck on a good day. Ive had one which will always be remembered: someone installed all manual resets in one of those. I dont know who or why but it was bad.
    Jul 2019
    That's funny.
    Worst thing is the safety reset and I never figured out which one it was. I am pretty sure it was over temp lockout when I got there but they had just replaced the filter so it was back to normal after I reset it. I haven't got a callback yet.
    Quote Originally Posted by Achso017 View Post
