Results 1 to 12 of 12
    Jan 2019
    Nest low voltage error
    Hi guys iam a new tech, i worked on a split system a carrier with burned contactor and bad dedrost board, replaced contactor and bypassed the board, got error message that nest is not getting volatage, i do have 28 v between red and common, the unit starts when i hardwire the thermostat wires (red+green+yellow)..i put an older battery powered thermostat the unit runs with it until i come back install the defroast board and try again with the nest.
    Any idea why the nest is not getting 24 v?
    Transformer is good, getting 240 and supplying 28v, hardwiring works,...
    Thanks!
    Jul 2019
    Oklahoma home its in the name
    It's a hockey puck.
    Sent from mars using Tapatalk
    Quite possible the NEST caused those issues.
    Trash the NEST and install almost anything but!!!!
    May 2014
    Bay Area California
    I saw the same thing on a heat pump. Low voltage to reversing valve caused it to vibrate and crack a tube. Dumped the charge, and the compressor ran until it cooked itself.
    That ended up being one very expensive Nest stat.
    Saw another one where the son gave his dad a Nest. Unit wouldn't work. Told the guy they were trash in commercial applications. But I could put a normal stat on if he wanted heat.
    If you were a real tech, you'd solder a relay on that board and call it good to go.
    I do a triple evac with nitro to remove non condensables.
    I use 56% silver on everything except steel.
    Did you really need the " If you were a real tech " ??
    Southold, NY
    NEST is POO
    Nov 2019
    Had one out here where the Nest would not communicate properly with the furnace (weak voltage). Ended up being a bad solder connection on the stat.
    Sent from my SM-G950U using Tapatalk
    May 2014
    Bay Area California
    Oh yeah, just remembered another one. A co-worker was on this one split system, heat pump. Unit kept icing up outdoor coil. So I get sent out. Told customer I couldn't do anything for him until he changed out his Nest to a conventional, he wouldn't go for it, especially since there was a sister unit that was working fine.
    A week or so later the office calls me saying the unit was acting up again. Told them I did a write to change out the stat to conventional, was it approved? They said no. I told the office, then there was nothing I could do.
    Owner calls me and asks what's up. Told him. He said just go out there and change the stat. So I did. And left the Nest on site hidden on a top shelf. Unit began working fine. I think he ended up putting some other brand wifi stat on.
    That was probably over two years ago. Only been back to that roof once to get info on replacing another unit for the property management. Don't know what the guy ended up doing. Or if we even still have the account.
    May 2019
    Central, IL
    We had a nest also low voltage on yellow , chattering contacter. Oddly it was intermittent problem.
    Nee pro 1 stat all good
    May 2018
    Elizabethtown, PA
    I've seen Nests kill a couple of contactors and a fan relay. If there's a Nest and an electrical issue, the stat is where I would start.
    Jul 2018
    I had a nest sending low voltage(<20vac) out on w. Changed tstat & had 28vac to furnace.
    Dec 2019
    Quote Originally Posted by george3 View Post
    Also had one sending 16vac out on W, changed it back to the conventional thermostat to give them heat.
    Dec 2019
    westchester ny
    go to settings and check your vin vout readings
