+ Reply to Thread
Results 21 to 35 of 35
Thread: Crankcase heaters
  1. #21
    May 2014
    Bay Area California
    Poorly insulated ?
    I do a triple evac with nitro to remove non condensables.
  2. #22
    Nov 2011
    CO
    Well, If you have a 3 watt heater, with the mass of a compressor, and 5* ambient.....what’s going to win?
  3. #23
    Dec 2014
    New Mexico
    The little bit of heat that is put in even at 5 degrees OSA will still cause the refrigerant to migrate else where in the system. The refrigerant wants to go where it’s colder.
  4. #24
    Oct 2002
    Plano, TX
    Quote Originally Posted by heatingelement View Post
    Thanks for the info guys!!
    How about the ones that have a temp sensor, seen several on the Trane units that close at like 40 degrees or something.. any benefit to that instead of on 24/7?
    Energy savings. 480 volt unit have a transformer with stat to power CCH. Way to many parts. Trane use to trickle current through windings to generate heat
  5. #25
    Oct 2002
    Plano, TX
    Allied RTU do not come with CCH. Ordered a factory low ambient kit for RTU. Still not included. So, I guess they don't think it the risk is there for damaged compressors.
  6. #26
    Mar 2015
    Medford, N.Y.
    Quote Originally Posted by stat View Post
    At Copeland school 25 years (Gene maybe?) ago we were told crankcase had no effect below 50F.
    Gene? Or Glenn Hannagan?
    My Copeland info in a Application Engineering Bulletin states that 0*F ambient is the boarder line for overpowering the heat produced by the properly sizes CCH.
  7. #27
    Sep 2014
    Portland, Oregon, United States
    This may be related..
    Today I noticed a larger carrier RTU maybe 15 ton. On the side of the compressor contactors it had a separate contacts which were closed but open when the contactor pulls in. Is this for the crankcase heater? It didn't have a wire diagram to look through. What is the technical term for these contacts? Should they be replaced at the same time contactors are replaced?
  8. #28
    Jul 2018
    Wisconsin
    Those would be called auxiliary contacts they are used for a few things including deenergizing the CCH while the compressor is on.
  9. #29
    Southeastern Pa
    Yes. Aux contacts (which are specific to the brand of contactor for reliable fit) should be replaced when the contactors are replaced.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  10. #30
    Sep 2014
    Quote Originally Posted by timebuilder View Post
    Thank you
  11. #31
    Sep 2014
    What is the best thing to do when the aux. Contacts are not available anymore? Carrier has contactors but the aux contacts aren't available. Go with a different brand of contactor?
  12. #32
    Jul 2018
    Wisconsin
    Leave them on all the time or you can go across one leg of the contactor.
  13. #33
    Dec 2014
    New Mexico
    Parallel the coil of contactor with a small relay to control heater on/off. See if you have enough room for a small relay and the coil of that relay’s amp draw won’t cause problems on the controller that tells the compressor contactor to pull in.
    This just adds more things to go wrong . Best may be to get all new contactor and six. switches. KISS (keep ,it, simple , stupid) No offense!!
  14. #34
    Southeastern Pa
    Or, you can let them run. Most of the units I see do not turn off the heaters when the compressors run. I see maybe 5% that turn them off.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  15. #35
    Southold, NY
    On all the time or relay
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
