Results 1 to 11 of 11
    Nov 2019
    replacing thermostats
    I replace a mercury thermo. with a new one on a 22 year old split unit heat pump. Every thing comes on the way its suppose to runs for a min. then cuts off I have the thermo. compressor protection set on 2 min. but the defrost board makes it wait 5 min. then it comes back on for a few min. and repeats this over and over.I checked the df board its an old gibson I cant make it go into df but every thing else works. Iam hoping its the board,welcome all help full feed back thanks.
    Sep 2016
    Is the thermostat programmed to be ran with a heat pump system?
    North Florida/South Georgia
    RFI - and lots of it
    We need a lot more information to help here.
    Model # of unit
    Model # of thermostat
    While the model number will tell us many things, you could provide some helpful details as well.......
    1 stage?
    2 stage?
    Mfr?
    Etc etc
    Also, what was the model of the mercury stat.
    All my leon freaked out!
    May 2014
    Bay Area California
    Indoor blower probably isn't coming on.
    I do a triple evac with nitro to remove non condensables.
    Nov 2019
    yes
    Nov 2019
    yes it is the old thermos. was a white & rogers don't know the model of unit it is a 1 stage cooling heat pump with heat strip the unit is a spilt unit 22 year old gibson
    Nov 2019
    yes the indoor blower is coming on
    Athens, Ohio
    Where have you measured voltage and what were the readings?
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
    edmonds wa
    At 22 years old , do you have it serviced yearly? could be other issues causing your problem.
    UA Local 32 retired as of Jan 2020
    Mar 2013
    DeLand, Florida
    Control voltage, maybe shorting out? Trace the t-stat wiring to the AH and then to the Cond.
    I love the line "Can you do it for cheaper?"
    I always say yes and leave.....
    May 2018
    VA/DC
    Quote Originally Posted by Capt Wolf View Post
    this is a solid starting point. when it shuts off does the compressor timer start? does it have batteries?
    I have had a bad contactor and every time it was energized the volts dropped enough to make the stat reset
