Page 1 of 5 12345 LastLast
Results 1 to 13 of 57
    May 2019
    Albuquerque NM
    Discharge Superheat
    Discharge superheat is one of those measurements that does not get much attention at least in my neck of the woods. Can somebody explain what it means when it is high or low and why it is important and also is there a typical range that discharge superheat should be at.
    Jan 2010
    You must have missed that marathon thread here
    May 2019
    Albuquerque NM
    Oops! Can you direct me to the thread?
    Southold, NY
    As the suction Super Heat goes up so does the discharge temperature.
    Keep the suctionSuper Heat between 20 - 40 and it should be fine!
    May 2019
    Albuquerque NM
    Thanks good to know
    Jan 2010
    Quote Originally Posted by Groghouse View Post
    It's well over 100 pages long someone here will most likely dig it up for you.
    Dec 2014
    Googs has tons of info too.
    John Tomczak can explain it well.
    You should know about it and measure it. IMO.
    Sent from my SM-G950U using Tapatalk
    May 2019
    Albuquerque NM
    Sounds good thanks.
    Nov 2014
    Northern Idaho
    Discharge Superheat
    Heres the thread. Got a good chuckle skimming back through it again.
    Accurately measuring suction superheat
    https://r.tapatalk.com/shareLink/top...ink_source=app
    Nov 2014
    Northern Idaho
    Reading through the end of that thread where bunny saves the day got me thinking. He’s mysteriously popped in on threads with excellent informative posts.
    We really should start a sticky “bunny archives”
    Jan 2010
    Your link ask to use Tapatalk
    Mar 2015
    Medford, N.Y.
    A little clarity here,ok. Are you talking "discharge line SuperHeat" or "discharge line Temperature"?
    Dec 2014
    Quote Originally Posted by GoCougs View Post
    Haha! Maybe I ment , Coogs, has tons of info.
