Results 1 to 13 of 15
    Oct 2015
    3mf 250v capacitor
    Do anyone know where I can get a 3mf 250v capacitor? It came off a motor on wellsprings yogurt machine made in Korea. It a round one, similar size to the blower capacitor. Supply house only carried 370/440V. Can I use 370/440V or I must stick with 250V? Thanks
    Jul 2019
    Oklahoma home its in the name
    You can always go up in voltage rating. Are you sure that is 3 mfd.
    Sent from my SM-J260A using Tapatalk
    Oct 2015
    Thanks for pointing it out. I couldn’t see clearly with the picture. It could be a 30mf, I will double check it tomorrow
    Jul 2019
    Research capacitors on hvacrschool.com and you won't have to ask next time.
  5. Likes CEAS-AC-TECH liked this post.
  6. #5
    Jul 2019
    They have a ton of good info
  7. Likes CEAS-AC-TECH liked this post.
  8. #6
    Mar 2018
    Chico, Ca #StateofJefferson
    Looks like a 30 to me, I only carry 440v caps. The voltage is just what the cap is capable of handling
  9. #7
    Yea, datsa 30!
  10. #8
    Oct 2015
    Yes it’s a thirty the percent sign% the small zero is place between the 3 and 0 which trick my eyes. Anyway I still couldn’t fine a 30uf that the same dimension as the one I pulled. The 30uf from the supply house is almost twice as big as the one I pulled. I need the exact size because it mount inside the motor. The new one I wouldn’t be able to closed the cover. Thanks
  11. #9
    Mar 2018
    Doubt you'll find that, can you mount it outside the motor securely and make some wire extensions?
  12. #10
    Southeastern Pa
    Where size is the issue, you may have to go with OEM.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  13. #11
    Jun 2006
    Voltage rating can always go higher on a capacitor, with no limit.
  14. #12
    Nov 2019
    San Antonio, TX
    Quote Originally Posted by stat View Post
    there is probably a limit for his application. Size seems to be one of them. I doubt you'll find a 5kv 30uf cap that will fit in his machine
  15. #13
    May 2018
    Elizabethtown, PA
    Try a motor repair shop. They tend to stock a much wider range of sizes ( dimensionally) than supply houses.
  16. Likes YingGiang liked this post.
