FANtastic
Customer just bought a home a week ago, called about a loud furnace. Showed up and fired it on to listen to what was going on, didn't take long to figure it out. 5 ton Goodman from 2004, had a new blower motor in 2008. The board was like that when I took the doors off.
Ain't got no time to re-mount the board after installing the high efficiency blower wheel shown in the photo's.
I do a triple evac with nitro to remove non condensables.
What would eaven cause that? I have never seen a blower wheel fail in person.
Sent from my SM-J260A using Tapatalk
"Is this before or after you fired the parts cannon at it?" - senior tech
I'm tired of these mediocre "semi flammable" refrigerants. If we're going to do it let's do it right.
Unless we change direction we are likely to end up where we are going.
"It's not new, it's better than new!" Maru.
But we tested it and the static was low.
Originally Posted by
R600a
Winner...
High static loads down the wheel, causes stress at the joints...
We have seen a few come apart...
Remember the Trane plastic blower housings back when... not pretty at all when they came apart!
GA-HVAC-Tech
GA's basic rules of home heating and AC upgrades:
*Installation is more important than the brand of equipment
*The duct system keeps the house comfortable; the equipment only heats and cools (and dehumidifies)
*The value of comfort, over the long term; leave economic choices behind!
Choose your contractor wisely!
I was joking about the fact that the static would be low in that condition
Does the high static cause over speeding from reduced load?
High static causes increased load...
Ever study a water pump 'cavitation'... it is VERY destructive to the pump...
GA-HVAC-Tech
Maybe with an EC motor. But traditionally, on a conventional blower motor, the more static, the less load on the motor.
ga-hvac-tech
Post Likes - 1 Likes, 0 Dislikes
ga-hvac-tech
NPSH is what affects cavitation not necessarily "high static". I believe the issue with deadheaded pump is more to do with heat building in the impeller and seals because no water Is being moved.
Cavitation isn't relevant to fans.
If the fan was running a super high static it would unload the motor on a forward curved wheel. Low static would overload the motor. I have nothing to offer on whether that is good or bad for the wheel.
The only thing I can think of that could damage a squirrel cage is vibration from imbalance or rough handling. I would be interested to learn if there was some other cause though.
I've seen the hubs get destroyed if they are windmilling backwards on start. The torque from getting it to go the correct direction is what takes them out. Generally on larger equipment.
That is interesting. What causes them to windmill?
BBeerme
Or multiple units tied into a single trunk
Ok that makes sense.
3/4 HP motor in place of a 1/3!
