Results 1 to 7 of 7
Thread: Carrier 48TC
    Nov 2019
    Carrier 48TC
    Have a Carrier 48TC that is having 2 blink limit switch fault then eventually 4 blinks. Both the roll out and limit switches are working and the indoor fan motor seems to be turning fine. When the unit is power cycled it starts and fires in the correct sequence. After a while the high temp limit switch opens with the 2 blink error then once it does it multiple times it gets the 4 blink error. When i find the unit in this state, only the inducer motor is running. Mod# 48TCED08A2A5A0A0A0 Board # LH33WP003A.
    Anyone have any ideas?
    Thanks,
    Troyblt
    Athens, Ohio
    Call a technician.
    Site rules do not allow advice for DIY.
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
    Athens, Ohio
    Quote Originally Posted by troyblt View Post
    KISS
    What should I assume since you posted in the Ask Our Pros forum instead of Tech to Tech?
    Virginia
    KISS
    Whoaaa my friend!!
    Not the way to get assistance on this forum.
    You are mostly to blame here, as you posted your question in the wrong forum. This forum is for commercial equipment owners to ask non DIY questions.
    Your profile states you are a tech, so if you want assistance, please click on the small black triangle at the bottom of your thread and ask to have it moved to the "Tech to Tech Chat - Commercial" forum.
    Please play nice when you get there, and go into further detail on how you determined the limit and rollout switches were "working".
    Athens, Ohio
    You won't get any help from me.
    Virginia
    Quote Originally Posted by kdean1 View Post
    I can't blame ya.
    My guess is he wont be back anyway.
    Whoa, take it easy. You posted your question the equipment/Building owner section, where tech aid aid is not permitted.
    Moved this to Tech to Tech for you.
