    Jun 2019
    So Cal
    Copper-Fin ll boiler and water heater
    Hello guys,
    For the past 4 days one of our Copper-Fin water heaters continues to go out on a code I cannot find a description for.
    The code is - LOCK OUT ADCERR JUMP S 1
    Anyone on here familiar with this code and or brand?
    Aug 2015
    Buffalo,NY
    Some information would help. Model and serial to serial to start
  3. Likes Jettinvr6sc liked this post
  4. #3
    Nov 2011
    East Side
    Yeah, there are different controls depending on the unit age.
  5. #4
    May 2018
    VA/DC
    whats happening is the supply sensor is raising temp to quickly. cause is slow water flow most likely. or if you have motorized isolation valves not opening enough. which is also creating a low flow situation.
    the supply sensor is a dual sensors. S1 and S9. S9 is a 20k and S1 is a 5 k i believe. ( not applicable to this questions, Just good info)
  6. #5
    May 2018
    VA/DC
    did you go to lochinvars website and get the service books? they have everything readily available for pdf downloads.
  7. #6
    Sep 2012
    Michigan
    It's a supply water temperature sensor issue. Had one doing the same thing, had to replace sensor. All is well since.
