Thread: T775 heads up
    Oct 2011
    Chicagoland Area
    T775 heads up
    I highly recommend bench testing any T775's before you leave the supply house. We've had a rash of them that have bad modulating outputs, sending out a constant 15-16vdc even when the display shows anywhere from 0-10vdc. We are waiting on a response from Honeywell.
  2. Likes CEAS-AC-TECH, icy78 liked this post
  3. #2
    May 2014
    Bay Area California
    Does Resido also make those?
    I use 56% silver on everything except steel.
    Did you really need the " If you were a real tech " ??
  4. #3
    Oct 2011
    Chicagoland Area
    EDIT The new software outputs default to 4-20 The old software defaulted to 0-10. The programming needs to be changed.
