Results 1 to 9 of 9
    Nov 2019
    PVC/CPVC HVAC ducts
    Can I use PVC or CPVC pipes as HVAC ducts in a residential attic? Would this violate any codes?
    I'm trying to make my AC system as efficient as possible to live through the Louisiana summers. PVC (or CPVC) seems like it would be a perfect choice of material for ducts. PVC is used for water pipes, so I assume it's safe to use for air. It's smooth, easy to seal, insulates better than metal, and I could install it myself. I have found a few articles in favor of it, but nothing from professionals. I figure I'm missing something. Does anyone do this?
    Thanks in advance,
    John
    Jul 2000
    Northern Wisconsin
    Whatever you use for the ducts in your attic it's all about how well you insulate them, not what they're made of.
    To get PVC pipe and fittings of sufficient size to move enough air for the average home would cost you many times than it would save over using metal.
    Insulate your attic and all the existing ductwork to recommended levels for your area and it will be money and time well spent and pay off in more comfort and savings in your energy bills for the life of the home.
    Jun 2014
    Dover, DE
    If you were to price 6-20 PVC pipe and fittings, youd quickly find out why it isnt used for ductwork.
    I havent failed. Ive just found 10,000 ways that wont work. - Thomas Edison
    Its not whether you get knocked down, its whether you get up. - Vince Lombardi
    Cost would be the primary reason PVC pipe isn't used.
    What style house do you have? Recently I have been building air ducts from sheet rock.
    PHM
    Quote Originally Posted by John1182 View Post
    Thanks in advance,
    John
    PHM
    S.E. Pa
    Can't. Gotta be rated 250 F by code.
    Nov 2019
    Thanks for all of the quick responses. The cost of PVC would be a deterrent, but the fire resistance requirement is a definite end that idea.
    I live in a ranch style house, and it currently has flex ducts. I can see bits of insulation coming out of most of the vent covers, so I figure it's time to replace them. There's also very little airflow coming out, so there may be leaks or they may be improperly sized.
    I plan to spray-foam the roof, and I'll go look into the different types of legal rigid ducts.
    I appreciate the help,
    John
    Southold, NY
    Find a contractor you can trust (easier said then done)
    They can replace the existing duct and make improvements where needed!
    Nov 2008
    Piney Flats, Tn.
    Quote Originally Posted by hearthman View Post
    doesn't that eliminate flexible duct?
    Flex duct is rated from about 0 to 250 - to meet that code requirement. I have sometimes wondered why it's so high. Maybe somebody here nows and can tell us? <g>
    BOCA says that sheetrock / drywall can be used for air ducts. In Florida I have been exploring it's use for air ducts. Some have been lined with 1/2" polyiso board and two have been just the drywall (to save some height) but so far all are working as intended. Although the application is mostly cooling with smallish electric resistance elements. Generally 5K with a discharge air temp of maybe 100. So nothing very 'high temp.'.
    PHM
    Quote Originally Posted by DOGBOY View Post
    PHM
