+ Reply to Thread
Results 1 to 20 of 20
Thread: Our computer and credid card machine keep turning off n on
    Virginia
    Gee that's odd
    I guess they ran out of red wire nuts
  2. Likes Dhumphries82 liked this post.
  3. #2
    Apr 2019
    That’s too funny.
  4. #3
    we only need to test it so just tape it up for now. when jimmy gets back from the warehouse, we will go back.
    "Right" is not the same as "Wise".
    Just because you can measure it, doesn't mean it is important. Just because you can't measure it, doesn't mean it isn't important.
  5. Likes Dhumphries82 liked this post.
  6. #4
    Jan 2012
    Broomall, PA
    How many conductors allowed in that box?
    If I do a job in 30 minutes it's because I spent 30 years learning how to do that in 30 minutes. You owe me for the years, not the minutes.
    Helpful Calcs, tips, tricks on my YouTube channel: https://www.youtube.com/channel/UCgm...TUTAdKmqRiTDEg
  7. #5
    Virginia
    Quote Originally Posted by STEVEusaPA View Post
    well sir , duct tape has 100 uses , so id say atleast 100 conductors
  8. #6
    Jul 2015
    After a while...……..I finally see the problem: the cover is missing.
  9. #7
    Jan 2012
    Broomall, PA
    Quote Originally Posted by thebigron View Post
    WRONG! It's the red wire nut on the green wires. Everyone knows red wire nuts are for red wires, and green for green wires...lol
  10. #8
    Dec 2006
    Vancouver, B.C.
    I carry that same wrap on silver wire connectors material in my truck. Didn’t even know what it was for. Next time there are too many wires to fit into a nut, now I know what to do!
    Quickly, I must hurry, for there go my people and I am their leader!
  11. #9
    R600a's Avatar
    R600a is offline Professional Member*/Membership Committee
    Jul 2019
    Hanging out with the mice behind the fridge talking bad about the roaches in the oven.
    I will be doing an install next week in a house where every connection is wired that way not to mention the a dash of aluminum mixed in. I mean exactly like that. Taped in open junction boxes.
    Sent from my SM-J260A using Tapatalk
    "Is this before or after you fired the parts cannon at it?" - senior tech
    I'm tired of these mediocre "semi flammable" refrigerants. If we're going to do it let's do it right.
    Unless we change direction we are likely to end up where we are going.
    "It's not new, it's better than new!" Maru.
  12. #10
    Virginia
    Before camera phones …. I re-did this indian convenient store by adding 20 outlets for 20 refrigerators the next indian was bringing in , and it had the same thing all throughout the basement except clear tape you'd use for xmas wrapping , with no covers
    Most of the tape had turned brown …and there were melted wires feeding outlets that wouldn't work ...that's so weird
  13. #11
    Nov 2011
    CO
    I did some work for a friend, they just bought a church. I was in the ceiling looking for a utility room light feed when I saw 2 pieces of romex cut off, laying on some tiles...both of them were still hot. they also had boxes with wires taped together. maybe it's the same ekelectrician?
  14. #12
    Nov 2011
    I came across one I haven’t seen before, someone used a wall anchor (plastic) to “wire nut” wires together, fortunately it was low voltage wires for a humidifier.
  15. #13
    What concerns me about that (the pic)...
    Lets say there was two circuits in that box... and one each of the circuits was from each leg of a standard single phase 240 breaker box...
    IF... that neutral connection fails...
    There will be 240 going through a bunch of 120 outlets...
    Seen this multiple times...
    It tends to let the magic smoke out of things...
    Which tends to let the magic smoke out of someone's bank account...
    GA-HVAC-Tech
    GA's basic rules of home heating and AC upgrades:
    *Installation is more important than the brand of equipment
    *The duct system keeps the house comfortable; the equipment only heats and cools (and dehumidifies)
    *The value of comfort, over the long term; leave economic choices behind!
    Choose your contractor wisely!
  16. Likes Fender60 liked this post.
  17. #14
    May 2014
    Bay Area California
    Really? I've never seen it even once.
    Quote Originally Posted by ga-hvac-tech View Post
    I do a triple evac with nitro to remove non condensables.
  18. Likes Fender60 liked this post.
  19. #15
    Quote Originally Posted by BBeerme View Post
    When the magic smoke goes away...
    Everyone looses!
    GA-HVAC-Tech
  20. #16
    May 2019
    Central, IL
    Common neutrals are technically allowed but must be fed from separate phases to eliminate over loading the nuetral.
    Not a real good idea though, as a loose nuetral will cause high voltage on one side and low on the other.
    Likely more important , if not on a double pole breaker , it presents serious shock hazard due to if shut off one breaker the nuetral is still hot.
    I learned this the hard way a couple times, lol
  21. #17
    Jun 2006
    Victoria, Texas
    That was shocking picture!
  22. #18
    Virginia
    yep , Ive had to repair 120v equipment that saw 220v from a rusted out neutral having 2 feeds ( i think that practice has been outlawed ? )
    This box however only has 1 feed , the black wire , so that cannot happen here
  23. #19
    May 2019
    Central, IL
    Still permitted by NEC .
    Circuits must be labeled as such
    Some municipalities have banned the practice
  24. #20
    Mar 2018
    They are permitted only if there is a common trip breaker for all circuits sharing the neutral.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
